Second hand 780ti for the same price. (210USD)
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
https://linustechtips.com/topic/734569-help/#findComment-9326594
3 minutes ago, deXxterlab97 said:
I would get a 980 instead
For like 270 on eBay? If you got a better deal than 250 send it via pm. I've seen ti s go for like 300
Specs v-v
https://linustechtips.com/topic/734569-help/#findComment-9326623
1 minute ago, deXxterlab97 said:
Still a worse deal for a 7th gen GPU from 2 years ago. I'd rather get a 480/1060 or 980
When it's still 6% better than the 1060 6gb? Also in rainbow six siege at ultra settings without aa, I got 150 fps on the 970 and the 980 got 160, I've seen 970s go for 120$ on eBay. I think eBay.
Specs v-v
https://linustechtips.com/topic/734569-help/#findComment-9326649
6 minutes ago, deXxterlab97 said:
780ti better 6%? Where???
4% close enough. http://gpu.userbenchmark.com/Compare/Nvidia-GTX-780-Ti-vs-Nvidia-GTX-1060-6GB/2165vs3639
Specs v-v
https://linustechtips.com/topic/734569-help/#findComment-9326695
I've tested both gpu's, the 780ti was slightly faster in the games I've tested at 1080p, no aa. But in higher res or with aa the 1060 did pull ahead. By a couple frames.
Specs v-v
https://linustechtips.com/topic/734569-help/#findComment-9326742
