5 minutes ago, GeorgeKellow said:
My friend has a Dell m2030 and he wants to start playing a few game like euro truck simulator 2 and project cars
He needs a gpu that is half height and single slot  no budget
For half height the options are fairly limited the 1050ti is one of the very few ones out there but it will be dual slot I don't think there is a single slot version.
Edited by W-L
https://linustechtips.com/topic/734539-gpu-help/#findComment-9326274
2 minutes ago, W-L said:
Oh just edited the message but no, I don't believe there are any good recent cards that would fit those criteria.
All I could find was this: https://www.newegg.com/Product/Product.aspx?Item=9SIA6ZP3R87916&cm_re=sff-_-14-129-297-_-Product
But it's out of stock...
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/734539-gpu-help/#findComment-9326308
1 minute ago, Morgan MLGman said:
Yes but that is also much less performance than a 1050ti, not many out there in that form factor.
https://linustechtips.com/topic/734539-gpu-help/#findComment-9326314
I know, this isn't anything ideal but it was the fastest GPU that was both half height and a single slot that I was able to find :|
https://linustechtips.com/topic/734539-gpu-help/#findComment-9326319
