CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($108.89 @ OutletPC)
Motherboard: Asus H110M-E/M.2 Micro ATX LGA1151 Motherboard  ($46.98 @ Newegg)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2133 Memory  ($50.98 @ Newegg)
Storage: ADATA Premier SP550 240GB 2.5" Solid State Drive  ($69.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.33 @ OutletPC)
Video Card: PowerColor Radeon RX 480 8GB Red Devil Video Card  ($219.99 @ Newegg)
Case: Rosewill REDBONE ATX Mid Tower Case  ($34.99 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($50.89 @ Newegg)
Monitor: AOC G2260VWQ6 21.5" 1920x1080 75Hz Monitor  ($99.99 @ Newegg)
Total: $732.03
Generated by PCPartPicker 2017-02-05 22:33 EST-0500
https://linustechtips.com/topic/733871-urgnt-help-need-pc/#findComment-9319418
This?
PCPartPicker part list: https://pcpartpicker.com/list/4rbVCy
Price breakdown by merchant: https://pcpartpicker.com/list/4rbVCy/by_merchant/
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor  ($197.99 @ OutletPC)
Motherboard: Gigabyte GA-B250M-DS3H Micro ATX LGA1151 Motherboard  ($73.98 @ Newegg)
Video Card: XFX Radeon RX 480 4GB RS Video Card  ($194.98 @ Newegg)
Case: Rosewill Galaxy-02 ATX Mid Tower Case  ($29.99 @ Newegg)
Total: $748.13
Generated by PCPartPicker 2017-02-05 22:36 EST-0500
lttstore.com
https://linustechtips.com/topic/733871-urgnt-help-need-pc/#findComment-9319430
16 minutes ago, Aubinstein said:
I have 750$ and need a pc and a moniter. I mainly play games like Battlefield, CSGO, Overwatch, etc.  Any help is greatly appreciated. Thank you
Set for upgrading to the i7 7700k
Includes a 1080p 75hz free-sync display
Possibly upgrade to an RX 480
PCPartPicker part list: https://pcpartpicker.com/list/QRWKGf
Price breakdown by merchant: https://pcpartpicker.com/list/QRWKGf/by_merchant/
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($70.98 @ Newegg)
Motherboard: ASRock Z270 Pro4 ATX LGA1151 Motherboard  ($117.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2666 Memory  ($55.99 @ Newegg)
Video Card: MSI Radeon RX 470 4GB ARMOR OC Video Card  ($173.98 @ Newegg)
Case: Cooler Master MasterBox 5 (Black) ATX Mid Tower Case  ($62.98 @ Newegg)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Newegg)
Total: $701.23
Generated by PCPartPicker 2017-02-05 22:39 EST-0500
https://linustechtips.com/topic/733871-urgnt-help-need-pc/#findComment-9319447
$17 over budget but you get an i5, an RX 480 8GB, and an IPS panel.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($188.69 @ SuperBiiz)
Video Card: MSI Radeon RX 480 8GB ARMOR 8G OC Video Card  ($224.99 @ B&H)
Monitor: LG 23MP47HQ 23.0" 1920x1080 60Hz Monitor  ($119.99 @ Newegg)
Total: $766.84
Generated by PCPartPicker 2017-02-05 22:42 EST-0500
https://linustechtips.com/topic/733871-urgnt-help-need-pc/#findComment-9319467
3 minutes ago, SteveGrabowski0 said:
Think I'd rather have a G4560 for now with a Z270 board for upgrading, take the bit of a performance hit now to have a better upgrade path
it's really not too far below the i5 in gaming benchmarks
https://linustechtips.com/topic/733871-urgnt-help-need-pc/#findComment-9319518
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($176.39 @ OutletPC)
Memory: Team Elite Plus 8GB (1 x 8GB) DDR4-2133 Memory  ($50.98 @ Newegg)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($43.74 @ B&H)
Storage: Seagate Pipeline HD 1TB 3.5" 5900RPM Internal Hard Drive  ($42.99 @ Newegg)
Video Card: PowerColor Radeon RX 480 8GB Red Devil Video Card  ($219.99 @ Newegg) $199.9 after rebates.
Case: Rosewill FBM-02 MicroATX Mini Tower Case  ($24.99 @ Newegg)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($46.98 @ Newegg)
Total: $753.03
Generated by PCPartPicker 2017-02-06 00:06 EST-0500
https://linustechtips.com/topic/733871-urgnt-help-need-pc/#findComment-9319739
If you use an Nvidia GPU, which adds cost and hurts longevity of the system. Digital Foundry in another video showed the same AMD DX11 overhead problem is still rearing its head when used with lower end cpus like the G4560. I think overclocking the cpu is a huge waste of money if you're not targeting 100+ fps, because that's when your cpu starts becoming a bottleneck. The build I suggested is much more balanced, and there won't be a need to replace the i5 in it for a few years.
The G4560 is a tremendous cpu for budget buillds (easily the best I have ever seen) but hardware is cheap enough now that $765 even with monitor doesn't necessitate having to skimp too much. The kind of build where I think the G4560 makes sense would be something like this, which would be really nice for Overwatch and CS:GO and still pretty playable for Battlefield 1 while coming in way under budget:
Memory: G.Skill Aegis 8GB (2 x 4GB) DDR4-2400 Memory  ($52.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 1050 Ti 4GB Video Card  ($137.99 @ SuperBiiz)
Case: Cougar Spike MicroATX Mini Tower Case  ($33.99 @ SuperBiiz)
Power Supply: SeaSonic 350W 80+ Bronze Certified ATX Power Supply  ($31.99 @ SuperBiiz)
Total: $571.24
Generated by PCPartPicker 2017-02-06 02:14 EST-0500
https://linustechtips.com/topic/733871-urgnt-help-need-pc/#findComment-9320077
5 minutes ago, SteveGrabowski0 said:
Even with the driver overhead in DX11 it's still over 60fps most of the time and it's on a game by game basis, plus whenever you eventually upgrade your CPU you got the Z270 platform and the 470/480 will fully stretch it legs
plus the 1050ti totally isn't worth getting over an RX 470 at least, the G4560 can handle it just fine
https://linustechtips.com/topic/733871-urgnt-help-need-pc/#findComment-9320090
If you buy the i5 from the beginning there is no need to upgrade the cpu for years though. So there is no good reason to throw money at the Z270 platform when on a budget like that. Instead of spending $120 on a board, $70 on a throwaway cpu, $350 on an unlocked i7, and $30 on a cooler (total $570) in an effort to stay relevant for 5 years he could buy a $200 i5 and a $70 board, in 3 years replace it with the new $200 i5 and $70 board, and he'd have a system relevant for say 6 years for a lower price, and he'd never have to game on a cpu bottlenecked system in the beginning. Unlocked chips are great if you're trying to push 100+ fps but I don't think they're a great investment for future proofing. I don't think it's an optimal use of money.
https://linustechtips.com/topic/733871-urgnt-help-need-pc/#findComment-9321161
The i5 will be fine, but it's simply overkill for 60hz gaming, and generally speaking it's only about $100 more or so to double your thread count, with an i7 you really will never need to replace it
the point is just to have the option for the i7, rather than being locked down
https://linustechtips.com/topic/733871-urgnt-help-need-pc/#findComment-9321561
