I have been experiencing wrist pain on the underside of my mouse hand. It is getting pretty bad. I only game for about an hour a day and do not use the computer much the rest of the day. I have tried changing my desk height, seat height, taking a break for a few days, doing stretches, using mouse wrist rests, using a wrist brace, using a chair with arm rests on and off, and holding the mouse differently. The mouse I am using is a razer deathadder chroma. I am pretty concerned about this as I love PC gaming, but will have to go back to console if this continues. I have been playing for about 6 months on PC. Any suggestions?
https://linustechtips.com/topic/733839-wrist-pain-solution/
Have you tried using a different mouse?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/733839-wrist-pain-solution/#findComment-9319135
Is it the joint or rubbing? When I used to play MGE in TF2 for hours a day, which requires lots of wrist snap movements, the underside of my wrist got chafed. That part of my hand has a low callous on it now, which I doubt is healthy, but if it is chafing then take breaks when it gets bad and go back when it feels better.
If if the problem is your actual wrist you may was to stretch it like the video @Aytex posted. Also you can grab your hand and pry up and then down, while keeping your arm in the same space. You should feel a stretch in your forearm.
Welcome to Maryland.
We have crabs.
https://linustechtips.com/topic/733839-wrist-pain-solution/#findComment-9319139
Who plays 12 hours a day,  my gosh. Well I used to know someone who legit would play 24 hours a day on weekends,  but still I've actually been playing less. Anyway,  have you changed hand positions,  does your wrist have any support?
Corsair 4000D RGB
Asus B550 Tuf Gaming II
Asus 7700XT Tuf Gaming
AMD 5600x3d
32gb 3200mhz gskil
https://linustechtips.com/topic/733839-wrist-pain-solution/#findComment-9319142
Why not get an ergonomic mouse?
People are affected by RSI differently. Some people don't get it at all whilst for others, it's a serious problem.
The mouse you're using is ambidextrous, ambidextrous mice are notorious for their poor ergonomics. I have a G602 at home, which has a noticeable slant to it to allow your hand to rest more vertically, 60-70 degrees from the desk is the optimal angle for me. When I worked, I had an ambidextrous mouse and it was horrible, it forced my hand pretty much flat which caused RSI. Getting a vertical mouse solved this. Vertical mice are usually cheap so get a cheap one to start off with then if you don't like it it wasn't a massive waste of money.
https://linustechtips.com/topic/733839-wrist-pain-solution/#findComment-9319151
