I have an old system i built. Specs of it:
E8500
Palit gso 9600
8gb ddr2
Gigabyte ep35c ds3r
5400 rpm sata 2 250gb hdd
450w prudent way psu
I installed win 10 on it and i had a q9550 on hand so i switched it so i had more power. I had an intel e8500 stock cooler and i thought that would be enough to cool it. So i powered on windows 10 with the q9550 in and it goes into the windows logo and freezes there. Is it a power issue? Is it drivers? If so tell me and if theres a solution
https://linustechtips.com/topic/733760-wtf-plz-help/
2 minutes ago, mlg_terrible said:
Yes. But crashes if you have to many windows open as it is a dual core
by crash do you mean blue screen, or is it just really slow?
core coun't won't make it crash, the kernel already runs 1000's or threads on each cpu
You probably have a bad cpu,
https://linustechtips.com/topic/733760-wtf-plz-help/#findComment-9318519
It crashes with the e8500. Like it just turns off. With the q9550 it freezes at the win 10 loading screen
https://linustechtips.com/topic/733760-wtf-plz-help/#findComment-9318735
