PSU ticking / buzzing noise under certain loads
Solved by PCGuy_5960,
1 minute ago, Walkure said:omg I had to youtube that up Yes it does sound something like that, so I suppose it's perfectly normal?
Coil whine is perfectly normal! For both PSUs and GPUs! You shouldn't worry... If you are concerned, you can RMA it, but IMO, you are 100% fine!
Redrooster ·
Posted in Audio0 -
Nik Donigan ·
B_T_B ·
Posted in General Discussion0 -
MathZone ·
Posted in General Discussion2 -
Puresonics ·
Posted in Troubleshooting0 -
Durrb IDk ·
Posted in Networking4 -
2
6
play_circle_filled
Latest From Linus Tech Tips:
The Most Awkward Upgrade…. AMD $5000 Ultimate Tech Upgrade
