3 minutes ago, Swinzon said:
It`s a Kingston DataTraveler 3.0 USB Device, can`t seem to find anything else.
It`s a USB 3 device fyi
You need a USB 3.0 port in the PC. From my personal experience USB 2.0 does around 30MB/s of transfer (copy/write) and USB 3.0 does around 90MB/s.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9316311
I got a USB 3 port on my PC?
5 of them to be exact, 2 on the case and 3 on the back of the mobo.
Plus 5 on a USB 3 hub connected via a USB 3 cable to the USB 3 port on the back
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9316314
32 minutes ago, Swinzon said:
Soooo, the web says that USB 3 can do up to 625 ish MB/s
That is the maximum speed of the USB connection.
but my USB 3 Kingston USB stick only transfers at around 30MB/s?
That is the speed of your thumb drive.
The speed of USB and the speed of the drive are 2 different things.
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9316352
This.
Plus often manufacturers use rather bad controllers, which are not really fast at file transfer.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9316362
Also, at just 30 MB/s you don't need USB 3.   USB 2 is good enough for that speed.
The just use USB 3 for marketing purposes only.
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9316374
225MB/s~ is what I can get with my Sandisk Extreme 64GB USB 3.0 stick :P
Obviously it depends on the USB drive you're using (i.e. what Nand it uses, what controller it uses ect.) sooooooo...ya know...
Also USB 3.0 can't deliver the full 5Gbps (0.625GB/s, 640MB/s) due to overhead and what not so real life speeds max out at around 400MB/s.
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9316412
But every USB drive that I have used caps at 30 MB/s, every damn external HDD and USB thumb drive...
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9316504
Maybe buying a SanDisk Extreme tomorrow...
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9316505
29 minutes ago, alextulu said:
Win 7 doesn't support USB 3, so it uses the USB 3 ports at USB 2 speed.
Wut are you on? Windows 7 definitely supports USB 3.0...
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9316617
This makes me question if those HDDs were really USB 3.0. Thumb drives are a different matter.
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9316769
That`s true, but when every god damn USB 3 device caps at 30MB/s? Every single god damn one?
Even my internal HDD`s hooked up to a SATA -> USB PCB thingy that I use to scan the hard drives caps at 30MB/s scanning speed....
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9319821
It's probably your HDD that's bottlenecking the speed.  I would imagine that your HDD has a max sequential read speed of 30MB/s.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9319837
Hahahah, lol :P
But that could be it yes, but still, every USB device that caps at 30MB/s? It`s weird, even my laptop which has the most amazing ever USB 3.0 SuperSpeed caps at 30MB/s...
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9319845
1 minute ago, Swinzon said:
Hahahah, lol :P
That's my point.   USB 3.0 has a high theoretical bandwidth, but it's still going to be limited by the slowest component.
If read speeds on your HDD are 30MB/s and write speeds on your flash drive are 50MB/s, it's only going to transfer at 30MB/s.  If you flip that, so read speeds on your HDD are 50MB/s and write speeds on your flash drive are 30MB/s, it will still only transfer at 30MB/s
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9319854
But I`ve seen many other people with the same External Drive get up to 100MB/s in transfer speed over USB 3.0?
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9319950
If I'm right, then it's because their internal drives have a 100MB/s sequential read speed.  Try copying something from your flash drive to your HDD.  I bet you'll see different speeds.
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9319958
A better test would be to copy from the external HDD to an internal HDD.
However it also depends on what you're copying. Copying 1000 files totaling 100MB is going to take a lot longer than a single 100MB file.
Also it would be nice to know what external HDD you're using. 30MB/s sounds like it's either a USB 2.0 device or the speed has been negotiated to USB 2.0
https://linustechtips.com/topic/733557-usb-3-cap-speed/#findComment-9319985
