Hey bros so my friend recently wanted to join the pc master race but his budget is only 2k USD, so I 2as wondering if you guys could help me out with the parts and he also stated that the monitor be included in the 2k budget and not to worry about other peripherals since he only wanted the tower and monitor.
Ps: (this build will not be completed till July since that was the date he was most comfortable with building it) , I don't that's what he said...
His preferences are:
Nvidia
Cheap aesthetic case with decent airflow
16 GB ram
1 TB HDD
24 inch wide curve monitor (preferably over 100 hz and with G-Sync if it's within the budget)
Cheap liquid cooling for the CPU or if unavailable air cooling is also good
Thanks guys!
https://linustechtips.com/topic/733505-help-needed/
Well, considering AMD's Vega and Zen will be out then, he should wait because both Zen and Vega might outperform their counterparts, and therefore be the better choice. Liking one company so much as to exclusively buy their products over another company's products is just a bad idea.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/733505-help-needed/#findComment-9315807
Nvidia
16 GB ram
1 TB HDD
Thanks guys!
only 2k usd? you guys in the US can buy a damn good rig for 2k usd. over here 14% tax gets put on everything (VAT) and then a crapton of import tax is added as well, Here in SA we pay over 640 usd for a 1070 and over 900 usd for a 1080. He can build a stellar rig for 2k
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/733505-help-needed/#findComment-9315846
Well that's what I told him but yeah his choice, on my build I was gonna wait for Zen and Vega but I needed a desktop for animation projects at the first week of Feb cause that's when I start school but yeah I had no choice but he does but I dunno he sticking to his piece of mind
https://linustechtips.com/topic/733505-help-needed/#findComment-9315855
Sell him yours and build a ryzen.  Solved.
There's something cool here - you just can't see it.
https://linustechtips.com/topic/733505-help-needed/#findComment-9315970
