Alright so the other day I was playing H1Z1 with the normal amount of lag at the beginning of each game with a slightly longer loading screen. Now today there's so much more lag at the start of the games and the loading screen takes about 3-4 minutes to load me in. What could be causing this and how do I fix it? I was just playing world of tanks before H1Z1 and it worked fine. I also don't think anybody would be on and using the internet at 1:30 am so that's another factor we can rule out.
https://linustechtips.com/topic/733479-internet-problems/
Hi,
I can throw some ideas out. I personally haven;t played these games so not to sure exactly how fast it  normally is ment to be.
1. Whats your internet speed on speed test?
2. Have you been on the community forums for this game and asked?
3. Have you rebooted your router and PC?
You can view your data usage for apps by typing 'data usage overview' in the search bar then after that you will see another option called 'data usage', this can maybe point to what apps are sucking the life out of your internet. I like to manually turn off all unnecessary services.
https://linustechtips.com/topic/733479-internet-problems/#findComment-9319842
1 hour ago, Osiris_RAB said:
Hi,
I guess it was just the game being buggy, it fixed itself after a while. I gave it to my friend haha.
https://linustechtips.com/topic/733479-internet-problems/#findComment-9320068
