Are there any micro USB cables that will last me more than a month? I have problems with its cables because they rarely last me more than a month. The connector itself on the devices are fine but the cables, no matter how well treated have to be angled to charge or don't charge at all.I've even had the metal piece just come right out. Should I buy a boatload of cheap USB cables?
https://linustechtips.com/topic/73339-a-somwhat-durable-micro-usb-cable/
I've had the same micro usb cable for various things for like 2 years (cheap one from ebay)
It gets used multiple times a day each day.
Its still like new.
Treat your cables properly and not yanking them out, what do you mean angled?
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
Its still like new.
Same
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
they're all the same
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
What I mean by angled is they have to be tilted to work. Yeah and some cables are just doomed, like my G930 cable. I don't yank on them but often times I use my phone while it is plugged in because it's battery sucks.
I wouldn't say I treat my cables bad. I just use them a lot.
MicroUSB is a terrible connector. I just bought a ton of cables (were on sale for like $0.50 at Fry's) because I use tons of devices that use MicroUSB. I still take good care of them and the connector always breaks eventually.
Thats a fault with whatever you are plugging in, not the cable.
Mine plug in straight.
You can't break these cables unless you put unnecessary pressure on the connector.
Yes its a fragile connector (could easily just grab the end and snap the connector of without that much force), no one says it isn't, but you can't break them unless you deserved it, take the connect out STRAIGHT, not yanking it out.  Don't treat them like other connectors which are allot thicker and can take the abuse.  Yes they suck, but its something you gota live with.
I would just make a DIY cap using something like cardboard to cover the micro usb from being bent.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
When you're charging whatever, don't let the cable hang off the side of a table or something. Always keep it supporting. Don't allow the stress to happen in the metal contact area. I've ruined a couple cables this way.
He's doing it wrong:
"When in doubt, don't take your wallet out." - Dad
† TTCF Member †
