time lapse help
You need to learn how to expose the camera properly and manually. Shutter speed is especially critical when doing timelapses, and using manual mode is important to maintain consistency between frames. You then need to learn how to focus the camera properly and manually. You then need to figure out a way of mounting the camera, whether that be with a tripod or ropes and common sense. If you're in a high wind environment use sandbags to weigh the thing down. You then need to work out how wet the camera is going to get. For example, if it's at a beach, make sure it won't get drenched by spray, and likewise if you're in the middle of a cyclone, ya dun goofy. You need to consider power supply and storage, this depends on the frequency of your images, how long they're exposed for and obviously how long you're shooting for. Once you've determined these things you have my permission to buy yourself an intervalometer (sometimes called a timing remote). They all do the same thing, so you shouldn't need to invest too heavily in one, some cheapo ones on Amazon will go just fine. Take your photos, then compile your images in your video editing proggy of choice. Consider using effects like the Ken Burns effect for maximum awesomeness.
Have fun man
