Will ENERMAX ECR501 is useful to me?
nonono
Hey!!!
iam not a frequent photo clicker and i also wanted to know is it good product to use?
please help
1 minute ago, dattharao said:
Hey!!!
iam not a frequent photo clicker amd i also wanted to know is it good product to use?
please help
Depends on what you do, lots of USB ports at the front is always nice, and a card reader only seems like a waste till you need it and you don't have one.
--- Purple Prime ---
i7 8700k + Hyper 212 Evo | MSI Z370 Gaming Pro CarbonG-Skill Trident Z 3000Mhz RGB 16GB | Gigabyte Aorus GTX 1080ti
Crucial MX500 500GB | WD Black 2TB | Corsair RM850i | Fractal Design Define R4LG 27UD68-P | Logitech G502 + G910 | Windows 10 Pro
--- Proteus Server ---
AyyMD Ryzen 5 3600 | Asrock B450m Pro-4 | Crucial Ballistix Sport LT 32 GB (2 x 16 GB) | Sapphire RX570 NITRO+ 8GB
Crucial MX500 1TB + Samsung Spinpoint F4 2TB + Seagate 1TB 2.5" + 5TB iDrive  | Windows 10 Pro (Temporary)
--- Camera Stuff ---
Canon EOS 77D | Canon EF-S 18-55 f/4-5.6 IS STM | Canon EF-S 55-250 f/4-5.6 IS STM | Canon EF 50mm f/1.8 STM
Zoom H5 + XY-5
Phone - Oneplus 6T
i have a card reader in my laptop but it his very slow in transfer speed
You will be better off getting a USB 3.0 card reader then, it can be moved between devices, although its annoying when you lose it.
Zoom H5 + XY-5
Phone - Oneplus 6T
so should i get enermax card reader ecr501?
Depends on your needs, If you read lots of memory cards then yes, otherwise, buy a cheap USB 3.0 SD card reader.
Zoom H5 + XY-5
Phone - Oneplus 6T
can you give me names of other card reader?
What is your location, i can find you a local one.
Zoom H5 + XY-5
Phone - Oneplus 6T
INDIA
Zoom H5 + XY-5
Phone - Oneplus 6T
these are all external ones which frequently disconnects and reconnects problem
If you want an internal one, get the enermax one.
Zoom H5 + XY-5
Phone - Oneplus 6T
ok and how i will get its warranty here in INDIA
Check the enermax site, if you buy off amazon it can be returned to them if it fails
Zoom H5 + XY-5
Phone - Oneplus 6T
