Help me cable manage please
Go to solution Solved by 19_blackie_73,
you could try to get rectengular adapters and run a power strip on the top of the table
Hi, I need some help. I'm a student in the UK and my accommodation has the weirdest placement of power outlets. My desk is stuck to the wall , even sealed with silicone on the sides. I have 8 power outlets directly above where the desk meets the wall. Cable management has been impossible. there is no place for my cables to go. My desk has a hole in the corner for cables, but it's unusable. I tried putting the excess cable in there, but it is a pain to manage when you want a little more slack in one cable. Also my laptop power brick wouldn't fit.
I can't wrap my head around how stupid this design is. Plugging something in makes the back 20 cm of the desk unusable unless i want to destroy the cable(given that i have a european plug for my laptop + adapter). They make it look like no big deal in the promo pictures, but in reality...
https://linustechtips.com/topic/731890-help-me-cable-manage-please/
My desk has this exact same problem. The only solution i could think of is running cables on the wall somehow which i gave up on so my desk is littered with cables
Well what do you have that needs to be cable managed other that your laptop charger?  I have a PC, monitor, fan, power strip, phone charger and router all plugged into the rear panel power strip just like that one and all I can do is lay my cables along the back of the desk and deal with it.  But most of my stuff do have 90 degree plugs so my cables aren't sticking straight out of the wall.
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
I've got my laptop charger, headphones, mouse and cooler ()whose cable is tiny thought). what made me write this is that i'm planning to get a mechanical keyboard and I could not stand another cable.
I guess I'll have to do that, I hope I can run the power plug of the power strip through the hole in the desk along with all my cables. Thanks!
I don't see why you would need to get a keyboard when you already have one attached to your laptop but to each there own.  My only solution is to just deal because you can't really fix it until you rent a sweet house with some buddies and are able to have full control of your living space.  Or you could get velcro straps or something and use them to bundle up the cables so they aren't just loose everywhere.
I really want to try a mechanical keyboard,  see what the hype is about
The hype is about the keyboard. You can type faster on a non mech keyboard,  for what it's worth. Not scientificly proven by any means but by experience.
Corsair 4000D RGB
Asus B550 Tuf Gaming II
Asus 7700XT Tuf Gaming
AMD 5600x3d
32gb 3200mhz gskil
