Hy I'm having some problems whit the cpu temperature. I just finished my build yesterday and at the beginning the temp was between 29 and 35 degrees now some times it gets to 43 45 just using regular programs. I'm using cooler master nepton 240m. I installed Asus ai suit 3 and it's controlling the fans. I don't know if to keep it or not the program or do something elese.
https://linustechtips.com/topic/731852-cpu-temperature/
It's not a problem until it gets hot. I don't know why you're so worried. Have you ran any more stressful tests on it like games or rendering?
edit: also what temp is your room?
qυoтe мe pleaѕe!
Me at the Apple store: "So how fast is this little macbook?"
Apple employee: "Cheetah Fast. Lightning Fast. It's Really, really, fast."
https://linustechtips.com/topic/731852-cpu-temperature/#findComment-9298030
That's not an issue what so ever
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/731852-cpu-temperature/#findComment-9298077
8 minutes ago, nuled said:
45 is nothing to worry about. As you say, you have a fan controller installed, if you are concerned, just increase the CPU fan rpm. Is the controller currently running fans at a lesser speed than before it was installed?
Yes it does
https://linustechtips.com/topic/731852-cpu-temperature/#findComment-9298192
