CPU Temps while gaming
Go to solution Solved by Lord Nicoll,
8 minutes ago, somerandomguy12 said:
I did the rice grain method on the thermal paste. I am actually running BF1 under minimum specs of BF1! (a 4690k which I think is ridiculous) and it is mostly at 100% utilisation. Could that be it? However, CS:Go runs at 65C
Is the fan working ok? That thermal compound is kinda old though, released between 2008/2009, so while it doesn't technically have a shelf life, it wouldn't hurt to buy some IC diamond or newer type of thermal compound. Make sure the fan spins freely feel the actual heatsink, make sure it's making good contact with good mounting pressure, and see how hot the fin stack is, if the CPU is hot but the cooler isn't, then there might be a bad mount, if the whole thing is hot then it's not up to par, and a replacement should be considered, 70°C is what I expect from a stock cooler.
5 minutes ago, somerandomguy12 said:
Would the i5 being a OEM one explain it?
No, OEM ones aren't all that different, you said 4460 right?
Hey guys,
I hate my CPU temps going high and my i5 4460 gets to 67-69C while gaming on BF1.
Should I be concerned?
my cooler is the Raijintek Aidos.
I have more dedocated WAM than you on my Minecraft server!
Specs:
RX 480 Sapphire Nitro+
i5 4460 w/ Raijintek Aidos cooler
XFX TS 650W PSU
Cheap OEM Acer motherboard w/ Cheap dollar tree Micro-ATX case
12GB DDR3 Decocated WAM
1TB Seagate Barracuda HHD
BTW I live in the UK so if I don't know where you live I will quote all prices in £
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/
2 minutes ago, somerandomguy12 said:
Hey guys,
Somewhat high for Haswell but overall not terrible. Worry should come if it approaches 90C.
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9293924
is to worth spending more on a better cooler?
Specs:
XFX TS 650W PSU
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9293930
1 minute ago, deXxterlab97 said:
That's a bit high. Here is my CPU temps for Crysis 3
I also have the RX 480. What cooler do you have?
Specs:
XFX TS 650W PSU
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9293939
Is your processor overclocked right now? If it's not, yes get a new one so you'll have more headroom. If it is then I would still get one just for cooler temps; in my experience cooler temps increase longevity of components. I watercool both my CPU and GPU and don't even overclock just because I like my shit to be nice and cool ;)
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9293946
Stock cooler.
how?!? Fan config?
Specs:
XFX TS 650W PSU
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9293948
It is a non k so.. not over clocked. What CPU cooler do you recommend as I can't fit the 212 EVO in my case. (155mm max headsink)
Specs:
XFX TS 650W PSU
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9293958
What is CPU usage?
100%
Specs:
XFX TS 650W PSU
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9293959
Wow I had a blonde moment, didn't even notice the lack of a k SKU. Whoops. Anyway, are you against water cooling? Most are very low profile and you can a descent one for around $50 if you catch a deal. What kind of case do you have anyway?
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9293971
I have a ThermalTake Versa H15 (Micro ATX and 155 max headsink) I an not against water cooling however, I am on a budget (under £30 (50 USD)) and I am inexperienced with water cooling
Specs:
XFX TS 650W PSU
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9293979
2 minutes ago, deXxterlab97 said:
Reapply thermal paste and see if it fixes. Other people playing i5 4460 on BF1 has temps around 50 too. Though 70 is not something to worry at all
http://www.ebuyer.com/450904-arctic-cooling-mx-2-4g-thermal-paste-or-mx2-ac-01?mkwid=sKAhvVucI_dc&pcrid=51508048139&pkw=&pmt=&gclid=COai9fam7dECFS8z0wodAwQEMA
Alright Thermal Paste?
Specs:
XFX TS 650W PSU
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9293985
Yeah but again. 70 is not something I should worry.
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9293989
Would the TX3 EVO be a good solution?
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-tx3-evo/
Specs:
XFX TS 650W PSU
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9294013
19 minutes ago, somerandomguy12 said:
Hey guys,
That cooler should do better than that. What TIM are you using and how is case air flow?
Yours faithfully
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9294021
I dont know that TIM is but I am using a push air flow system with 2 intake 1 outtake. I use the MX2 thermal paste.
Specs:
XFX TS 650W PSU
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9294032
TIM = Thermal Interface Material. How's the coverage? 2 Intakes and an outtake should provide plenty of airflow unless they're at like 30% speed. Maybe reapply the thermal compound and see does it help, but it should be better than that. I HIGHLY doubt the heat pipes are bad, it could just be your CPU's a particularly hot one or BF1 is hitting all 4 cores at once, which it does.
Yours faithfully
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9294048
TIM = Thermal Interface Material. How's the coverage? 2 Intakes and an outtake should provide plenty of airflow unless they're at like 30% speed. Maybe reapply it and see does it help, but it should be better than that. I HIGHLY doubt the heat pipes are bad, it could just be your CPU's a particularly hot one or BF1 is hitting all 4 cores at once, which it does.
Specs:
XFX TS 650W PSU
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9294065
Specs:
XFX TS 650W PSU
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9294076
Yours faithfully
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9294098
No, OEM ones are all that different, you said 4460 right?
yes, i5 4460. I might get a new cpu cooler and paste then.
Specs:
XFX TS 650W PSU
https://linustechtips.com/topic/731471-cpu-temps-while-gaming/#findComment-9294103
