Hi Everyone, for my PC, it has a built in LED logo and to power it I have to use the PERF cable or Molex cable to attach it to my PSU. But I also have the NZXT hue+ and that requires a molex cable to power it. Am I supposed to use a double molex cable and attach it to my PSU to power both since my PSU only has one PERF slot?
https://linustechtips.com/topic/731213-question-about-molex-cable/
What PSU...
11 minutes ago, Tweed said:
EVGA P2 850w
All the ports labeled sata are the exact same thing:
Image result for EVGA P2 850w
1 minute ago, Tweed said:
So do you advice that I get a double molex or 2 single molex. I'm getting custom sleeved cables fyi.
Double so that there is less cable clutter.
Hey @Tweed check out the CableMod configurator page where you can make a dual Molex connection by color and to your desired length.
https://store.cablemod.com/configurator
