Homework help
Go to solution Solved by kelvinhall05,
10 hours ago, Mug said:
first one, pick 5 numbers that add up to make 500. Any numbers.
I picked 101, 102, 103, 98, 96.
second one, pick 3 numbers between 71 and 79 that add up to 225.
I picked 73, 78 and 74. The numbers of this answer is therefore 71, 79, 73, 78, 74. Easy.
How? Well, rearrange the equation you use to get averages, times the mean by the number of numbers (5) and you'll get the sum of the numbers. From there, you can easily pick numbers. You could even pick ludicrous numbers as long as they all average out.
10 hours ago, Dash Lambda said:
To find a mean, you find the sum of the items and divide it by the number of items. Therefore, for a given mean, the items need to add up to that mean times the number of items.
So, let's say I want to find 3 numbers whose mean is 10. Since I would divide the sum by 3 to get 10, I work backwards and find that in order to satisfy the mean, the numbers would have to add up to 30. At that point, I just choose any three numbers that add up to 30.
For the second question, you do the same thing except you just add the condition that the difference between the highest and lowest number is your range.
So, if I wanted 3 numbers with a mean of 10 and a range of 5, then I could choose as example 8, 13, and 9. The range is 13-8=5, and the mean is (8+9+13)/3=10.
I know how to calculate it, just not this specific problem.
Anyways, my dad came home and helped me, thanks anyways!
Can someone help me with the last 2 questions on my homework? I'm supposed to find 5 numbers that (combined) have a mean of 100, and another 5 numbers with a mean of 75 and a range of 8. I know how to do range, mean, median, etc. but I need some help. Can you help me? Thanks!
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/731022-homework-help/
https://linustechtips.com/topic/731022-homework-help/#findComment-9289691
"Do as I say, not as I do."
-Because you actually care if it makes sense.
https://linustechtips.com/topic/731022-homework-help/#findComment-9289704
SPECS:
https://linustechtips.com/topic/731022-homework-help/#findComment-9291633
