Project „SL5T“
"SL" as you already know from Mercedes Benz, is to make the first impression what this project stands for. Elegance, luxury and simple forms.
The MasterCase Maker 5T is used.
The interior is as discreetly as possible cleared of all unnecessary elements.
The walls are clad with Plexiglas and multi-layered in the design of the mainboard.
An elaborate water cooling system is installed which, however, is kept as minimal as possible.
A cover is made for the cable area, which provides a window for the PSU and on which the ASROCK logo is placed in case size.
The logo is framed with the design of the X99 Gaming I7 as well as I would like the elements of the mainboard to continue the whole case. (The red racing arrows between the lower two PCIe slots)
All cables are sleevedin the hardware colors.
From the outside the contours of the Maker 5T are emphasized by Plexiglas, where also sponsor logos will be found.
So much for the formal part.
The Maker5t will be my next Rig, since I have not yet a good portable Gaming PC.
So I have now also evasive possibilities when my table times problems and above all I can finally also times my table new hardware miss.
Actually, I wanted in this project not so much effort to operate but again will grow the mod again tremendous.
Since I now the first time on a separate X99 board change, I dedicate this mod to the
ASROCK X99 Gaming I7
And let the whole project be inspired by the mainboard.
Hardware
CPU: Intel Core I7 6850K
Mainboard: Asrock Fatal1ty X99 Professional Gaming I7
Ram:
SSD:
GPU: Nvidea Geforce GTX970
PSU:MasterWatt Maker 1200
Case:MasterCase Maker5t
Watercooling
Bitspower NGTX970MGV2 Acrylic (Clear) BP-WBVGNGTX970MGV2NPAC
Bitspower Leviathan Xtreme 240 4xG1/4" Radiator BP-NLX240-F4PB
Bitspower Leviathan Slim 280 4xG1/4" Radiator BP-NLS280-F4PB
Bitspower DDC Plus Pump BP-DDCPLS
Bitspower DDC TOP Water Tank Integrated Kit 300 (POM Version With Z-CAP II) BP-DDCTOPWTIK300PC3-BKCL
Z-Tube 250( ICE Red) BP-WTZACT250-IRD
Bitspower DDC Pump Cooler Bracket (Red) BP-DDCPCBT-RD
Bitspower Pump Cooler For DDC/MCP355 (Red) BP-DDCPC-RD
Bitspower CPU Block Summit EF (Intel) (Acrylic Top Version) BP-WBCPUIAC-CUMBKWH
Bitspower CPU Block Plate For Intel CPU (Deep Red) BP-CPUIPT-DRD
Bitspower G1/4" Deluxe White Enhance Multi-Link For OD 12MM BP-DWEML
Bitspower G1/4" Deep Blood Red Enhance Multi-Link For OD 12MM BP-DBREML
Bitspower Deep Blood Red Enhance Rotary G1/4" 90-Degree Multi-Link Adapter BP-DBRE90RML
Bitspower Deep Blood Red Enhance 90-Degree Dual Multi-Link Adapter BP-DBRE90DML
Bitspower Deluxe White Enhance Rotary G1/4" 90-Degree Multi-Link Adapter BP-DWE90RML
Bitspower Deluxe White Enhance 90-Degree Dual Multi-Link Adapter BP-DWE90DML
G1/4" Deluxe White Rotary 90-Degree IG1/4" Extender BP-DW90R
G1/4" Deluxe White Mini Dual G1/4" Extender BP-DWWP-C42
G1/4" Deluxe White Rotary G1/4" Extender BP-DWRG
G1/4" Deluxe White Muti-Transfer Adapter BP-DWWP-C03
G1/4" Deluxe White IG1/4" Extender-15MM BP-DWWP-C60
Deluxe White Mini Valve With Black Handle BP-MVV-DWBK
Deluxe White Q Plus-Block BP-DWFMB
G1/4" Deluxe White Stop Fitting BP-DWWP-C06
Bitspower None Chamfer Brass Hard Tubing OD12MM Deep Red - Length 300 MM BP-NCBHT12DRD-L300
G1/4" Deluxe White Aqua-Pipe I BP-DWWP-C17
G1/4" Deep Blood Red CaseTop Water-Fill SET BP-DBRWP-C04
X-Station Mini Power-Extension I Female Version BP-MINIXSP1F-RD
Bitspower Logo Aluminum Thumb Screw For 632 (Deep Red BP-LATSC632-DRD
Bitspower Logo Aluminum Thumb Screw For 632 (White) BP-LATSC632-WH
Bitspower Metal Tubing Cutter BP-CMMTC
Bitspower Flow Indicator BP-FI-CLBKWH
Red Blade For Bitspower Flow Indicator BP-BFI-RD
Control: Aquacomputer Aquaero 6 XT
equipment
Fan:2 x NB eLoop B12-1 ,3 x NB eLoop B14-1
Headphone:MasterPulse
Keyboard:MasterKeys Pro M
Sketches
In order to bring the project as smoothly as possible, I took this time a bit more time on the computer and already times sketches for the different covers created.
The elements are glued together in several different colors.
Partially varnished, partially foil and partly (only) polished.
For use comes Plexiglas in various colors and thicknesses, aluminum foils and varnishes.
This is only the rough basic idea, should expect again but not look good I let myself think of something else: thumbup:
This cover comes on the right side in the case inside where the drive bays sit.
To the right the original pattern and to the left the lighting effect.
Here the front, whether the red arrows will really work well, we will see
Here the front of the PSU cover, the design on the left will frame the window to the PSU
And here the elements for the Windows, not completely in red but as template it is enough
Hardware pic´s
The majority of all components are already there, but see for yourself:
A big thanks goes to all who support me with this project:
ASROCK
COOLERMASTER
BitsPower
Blacknoise
Avexir
https://linustechtips.com/topic/730390-project-sl5t/
May I ask, why do you have a 6850K with a 970? What use case is this system for?
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9281870
maybe he needs CPU power and not much GPU power
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9282091
That's why I asked the use case... also 6850K is mostly just a 6800K with more PCI lanes, and he isn't running 3 or 4-way SLI so why pay more? Spend that extra cash on a 1070. For gaming with a 6800K+ though I expect no less than at least 1x 1080
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9282151
maybe he has plans for a lot of NVMe SSDs and extra things that uses lanes or plan on a upgrade to SLI, but yeah I agree this seems a bit weird.
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9282182
Hi ! Nice that someone here has noticed.
First,the 6850K was a gift.
The graphics card is only used to finish the project, then immediately comes a 1080 pure.I'm still waiting.
It´s a extreme gaming 1080 full cover waterforce, for a clear Bitspower Mod, the extreme cooler does not look so good.
:P ;-)
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9282335
  • 2 weeks later...
Hi!
After the case was made naked, I had to realize that my radiator constellation was not as fit as I wanted.
After a long time, I had to saw.
The 280er does not fit above and the 240er comes extremely far down then the piping then the mainboard would cover, so the 280er upwards.
The yellow taped points I will cut first.
The second marking is for the 8Pin Atx cable which is exactly centered with the Gaming I7. Sloping cable routing is not my thing, so I will enlarge the cable lead.
In order to work there clean, I had to remove only the rear handle from the case.
And then everything clean, in the taped condition, cut open
With the radiator bracket I had only the rear wall cut off
The ATX cable bushing I cut up well on the double size and of course, once slipped off and the paint damaged.
Since I have already tried massively in different colors it meets this here with best but wanted to use and I will not continue it.
Then I riveted the handle from the case immediately and the rivets painted black (right), all interfaces of course also ..
Then I once cut all possible materials, cut patterns created, plotted and transferred to the material.
0,75 Alu for the Midtray
2mm Plexi for the HDD Cover Designs
3mm plexiglass red fluorescent as base plate for HDD cover and The X99 Arock arrows for the Windows.
Now it was also starting with the sawing, first the 2mm Plexiglas
Then the aluminum sheet
And the Decals for the Windows
After the sawing of the 2mm strips I have now all these on neat gaps, straightened and sanded.
The still black stripes come then in 3mm Plexi
Which I have sawn out next
Now I fixed all strips with double-sided tape and the dimensions for the base plate marked
Then I have the 2mm Plexiglas again completely ground, cleaned and with double-sided tape on a sheet glued so that it does not fly away from the paint.
The base plate is now also tailored
The edges I have all slanted to the half to 45 degrees. The outer edges with the top cutter and the inner edges by hand
The sheet metal for the Midtray was now completely cut and then folded.(bent)
Now I have cut 2mm aluminum for the PSU cover and cut a few small angles as a bracket and soldered together (also here: does not ask how, absolute disaster but it holds)
Now I have transferred the designs to the PSU cover
The Aquaero must be a bit deeper, so I have now torn all the surfaces to be sawed
Everything still nice straight cut
And the section for the PSU still slightly bevelled
So that would be status quo.
Next, I'm trying to create an inlay for the PSU window, hope it works out the way I've seen it with some others. Is indeed something angular.
And for the front of the case I'm still looking for inspiration. I just can not think of what I do best under the arrows, where the Cooler Master logo sits. Something has to be there because otherwise it looks boring.
So many thanks for reading, until the next update!;-)
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9322652
Hi Guys!
Go on.
After transferring the designs to the Plexiglas, I also cut these out
then tailored for the small strip on the far left a few times 2mm strips
Actually the red plexiglass should be polished but these small 2 x 20mm strips all the same to grind brought me to white heat. So I glued the small stripes with epoxy glue to the aluminum and just sanded them after curing.
The Red Plexiglas later foiled everything anyway. I just wanted the UV effect of the polished edges. But in this one place I will be able to cope with it. These strips are then painted with. ;-)
Two aluminum brackets have now been cut for the holder of the Aquaero
In this form, the entire cover did not fit into the PSU bay anymore. I thought I had to shorten the whole aperture still a bit but the angle adjust has also helped.
Since I have failed with the actual midtray miserably as far as the soldering, but it left me no rest,
I still had to practice and test something.
Screws I wanted here actually very reluctant.
Somehow it worked then, I believe at least.
It looked quite ok for a few remnants
So I now ventured to the correct angle.
Everything with as little contact with other surfaces so that the heat can not be dissipated as quickly and as a base a granite slab. Last but not least, the veneer of the workbench flown around my ears, they gave a loud bang XD!
So everything neatly sanded and degreased and then everything for soldering eigespannt.
I am really satisfied with the result. In the sample I did not have such good capillary action.
The window for the PSU I now cut from 2mm Plexiglas and polished all edges.
I have now completely glued on a 1cm larger plate
Is a little bubble but I like the effect. Thanks to the brass pipes of the water cooling you will not see any water in the system anyway.
The holes for the PSU aperture were still set at an angle behind I cut thread
The patterns for the front I have all transferred to 2mm Plexiglas and sawn.
Who knows?
Here I have already made the first changes to the original file?
I have here, incidentally, two 2mm slices glued together and both with a dishwashing cut;)
The two elements above the arrows I have cut from 2mm aluminum because I want to bend here a small rod
I have now marked these rods and cut them with the fine-boring grinder, which, by the way, did not say goodbye after two years. Man again buy new machine grrr
These I then clamped between two steel strips and worked something with the hammer until I was satisfied
Jooooo, So beautiful I could not even imagine it  :D
Oh so on Sunday I wanted to spare my neighbors times a bit so I began to polish some parts of the red plexiglass
All these here
I cut off all cutting edges with a Cutta blade, then polished from 320 (400, 600,) to 800 paper wet and finally polished with two polishing pastes on high gloss.
Pagan work, man man and that was not even half
In order to see slowly times to go forward I began yesterday with the paint.
Will finally also see whether it all acts as I imagine it before it goes with the other surfaces.
Aluminum got a special 1 / K aluminum primer and the Plexiglas I primed with plastic adhesion mediator.
Then continue working with spraying spatula.
My workshop is definitely too small  :|
So then, let's see how far I come next week.
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9359471
So it goes, after I had to grind all parts again and rework
Everything was painted
Afterwards, all parts were fixed to the base plate and glued with Acrifix 1S 0116.
As expected, of course, I slipped a few times with the syringe, damn grrr
The attempt to paint it was not particularly satisfying. I will foliate the places later
Despite all this, I am very satisfied with the color concept. I like it:thumbsup:
After a long time, I think a good design for the front and the top. It is a mixture of 2mm and 3mm Plexiglas combined in high gloss and matt.
So now I began to transfer all the patterns to the Plexiglas and cut them out
The front
and the top
Besides, I disconnect a graphics card from Light Glass, it hurt: heul
and this converted to Bitspower.
For that, the PCI bracket had to be folded again and painted black
For the HDD Cover I now still cut a second plate in white and for the strip of the front plexiglass 2x6mm
All parts for the top and the front are now bevelled (is there a term for this in English?)
Now the Coolermaster logo away with 2x polyester 2 / K spatula
And then I glued the 6mm strips on the front, fixed with seconds glue and the outer edges all closed with Acrifix, really complicated because the front is slightly bent.
after the glue was dry, I then again revised the ends of the strips until all straightened with hand and power file, minor damage were 2 / K spatula
Then everything again primed and varnished
Now the edges of the white plate are polished and
So the result.
Here everything is already positioned for the water cooling and measured whether everything fits so far.
Therefore only the pipes have to be cut.
so then, see you soon!
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9395104
Many Thanks! Nice that you notice it. :D
Here is the next update!
I could last night unfortunately only 3h sleep then work 9h and 20.00 we have to take a night shift so I shall be brief
There is not much to say, the pictures speak for themselves.
Since the red film is a little translucent, I decided to double everything with film, so first black and then red.
Here are the small items around the PSU Window.
Then I the last week only polished
The black plexiglass was only frosted with 600 wet abrasive paper.
Is hardly recognizable in the photos.
Then it went to filming, first everything with black foil and then with red foil
Comes cool 8)
The small elements of the PSU window were made of burgundy foil which fits perfectly to the mainboard, the red foil is matching the case
Then everything was glued with transparent silicone to the Windows
And then lettering with white foil
Here the PSU window, glued with silicone, the small varnished strip I have previously covered with the burgundy foil
At the front there were some problems, as the front is slightly arched, the plexiglass was under tension and did not hold.
So everything had to clean again and paint again.
The plexiglass I have still slightly warmed and bent before the second attempt before I have attached it with epoxy glue.
With the other elements I am exactly the same.
Yeah !! I like it  :D
Unfortunately, I had occasionally epoxy glue on the hands and the many cleaning of the surfaces, the paint was so strongly attacked that I had to paint everything again.
I really wanted to avoid it, but I could not let that happen.
Soo I like it better
Short and sweet ;-)
This week comes the top and hope also the cable sleeving or tubing.   8o
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9434727
5 hours ago, CapTen said:
-snip-
OH MY GOD you need to enter some modding contests this is one of the most detailed and beautiful mods I've seen, better than a lot of huge companies can do!
Great work, would love to see more!
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9436296
Hey thank you. Oh i take part on the coolermaster case mod world series since two years.
I won trophys the last two years on different contests in Germany. DCMM (Germanys casemodding championship) 2015 second place for scratch build and 2016 2x third place on scratch build and case mod. 9_9
you can visit my Facebook page to see other mods from me.;)
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9439281
Hehe, the moment I saw you say "280er" in one of those earlier posts, I knew you had to be German... :)
Absolutely lovely case mod though! The basic aesthetic of the system is somewhat too gamer-y for my tastes, but it's carried out with great consistency throughout the build, and the mods to the front panel in particular look so seamless that I'd believe you if you said it came out of the factory like this.
Genuinely great stuff!
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9440768
Hey thank you rjfaber91!
Yes i am german:P
It's Monday, time for next update;)
Now I've upgraded the backplate visually.
For this I have two red 3mm plexiglas plates cut and glued together
Then I cut these a few days later in shape and from 3mm to 6mm slanted obliquely, it unfortunately got badly photographed
Then everything completely matted and glued to the GPU.
I've also added some of the motherboard's design.
Then it went with the foiling of the parts of the top
Because then I noticed that the foil to little is. Well sometimes you have to see it all before you.
I then began to edit the parts again
Besides, I have cut a new logo for the front and painted this silver
Now I finally finished all the parts and glued to the case with epoxy glue
Then it was time to lay pipes
Also here a few holes had to be set
matching the honeycomb design I have two spacers built so that the case does not protrude throughs so far inward
And here the finished loop
As you can see in the last picture, all PCI Thumscrews were exchanged for white, and others were used at PSU
Somehow I thought the PSU cover was too unstable, the gap around the Aquaero have often changed. I thought 2mm Alu would be enough but so I now have two aluminum angles cut, primed, painted and glued to the PSU Window
Yesterday I started already with the sleeving of the cables. Actually already last week but with the Masterwatt is a sleeving 1: 1 not possible so I had to reject the plan and create now only Extension.
The pump I have already finished :rolleyes:
So it is slowly coming to an end, but it still remains exciting as the cables all can be optimally laid and above all as I bring everything to the Aquaero:vain:
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9476392
4 hours ago, CapTen said:
snip
One of the best and most complete case mods I have ever seen!
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9477993
  • 3 weeks later...
Thank you very much sir!
Next and last update comming soon.
The case mod is now without ram/ssd on the CEBIT, but the ram came of course this week.
As soon as the mod is back again I build it and make the final photos.
:D
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9572411
Now the next update.
Before the Cebit did not have much time and now I wait for the mod to come back again:D
So ..... what had to be done:
For the correct installation of the front radiator a few holes had to be changed
The HDD cover got to fix still angle
The Aquaero has now finally its black aperture
The Flexlights for the interior and the PSu Window were soldered and sleeved
In the midtray was still a hole for a few MB cables and the GPU lighting set
The Sata cables I have shortened to a single connection. This is also quite easy. From the last Sata connection simply the cap carefully lever off and then the cable over the required plug as scarce as possible cut off. Now put the cap back on exactly this plug and done
At the MB tray was as always exactly there a strut where the ATX cable should run, so also had to be helped here again.
Since I no longer need the grommets of the midtray I could make a new execution for this big hole
At the top there was still a vacancy which looked a bit dull, so I cut a little bit of aluminum, painted it and then covered with the red foil
The extensions are now all ready
Since one under the IO-Shield the radiator saw had to be made for this still a small aperture
First the pattern taken
Then cut out the appropriate piece from the front grille
On this grid are two stripes which I originally wanted to leave in red.
First sawn a 3mm strip and then ground in shape
In red but it did not really fit so I painted black with two layers of clear lacquer
The whole I then somewhat offset to the front fixed and with silicone glued
Shortly before I have still two red LEDs set so that the slots in the front light
All cables tidy hidden under the insulation
The GPU got red LEDs
The headset I have now also an individual touch given
Since the mussels are slightly arched, the Plexiglas had to be slightly bent
The PSU Window left me no rest. I then found a good tutorial for cementing plexiglass.
Important is polyester adhesive tape. So again a small window cut, adjusted, polished edges.
Apply the polyester adhesive tape completely to the surface to be glued, then place the window on it and gently cut it with the scalpel once. So I now have a perfectly mashed surface.
Remove the center tape now, of course. Then apply abundant to full acryfix and press the window gently free of bubbles.
This time I have accelerated the drying process additionally with UV light, just in bad weather, the sunlight simply does not matter. I think it was also often to bubble formation so that the glue usually after 24h was not 100% hard. With the UV light I could break off the glue easily after 3 hours with a chisel.
Stupid, I have the window on the wrong side glued XDXD but you can recognize the difference to the first attempt. No more bubbles and full glue on it ;-)
So all good things are 3. Unfortunately, 4-5 photos from the window have not changed anything but I will finish it in the final pics in detail.
So, because I did not like the burgundy foil on the PSU cover with the red Plexi behind it, I painted it all black. Also the honeycomb covers of the Bitspower housing feedthroughs
And then with the case colored red foil.
The radiators were also painted in white and the slats with a red metallic lacquer
In order to make the back a bit more photogenic, I have also continued here the red arrows
Also these holes in the case did not please me
then everything foiled red again
Now again a dangerous matter. The Windows had to be adjusted something so I can continue to use it. Since some covers were closing in the way, I had to separate something from the steel of the Windows.
Since glass can crack quickly with the sudden contact with heat I am very cautiously proceeded and have repeatedly inserted breaks at the cutting.
But first I have the whole window with foil protected and then still an old rag for the protection against spark hung before it.
So that was it! The memory and SSD has now finally arrived. So once I have the case again I can finally make the final photos  :phat:
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9586618
  • 2 weeks later...
2 hours ago, CapTen said:
-major snip-
Genuinely the best looking PC I have seen in a WHILE. Amazing work!
Just look at the frickin curve of the GPU power cables... sexy as hell
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/730390-project-sl5t/#findComment-9659886
