Hey all,
I've a friend who wants to get into PC gaming.
I'm no good at budget builds but it basically needs to run your standard games, GTA V/COD/CS:GO etc..
Please advise parts to get minus an OS, Monitor, Mouse & Keyboard and to a budget of £550 inc.shipping?
May be a tall order but any help would be great, thanks :)
Don't forget to @me / quote me for a reply =]
https://linustechtips.com/topic/730294-pc-build-for-a-friend/
might be a few bucks over after shipping on a few parts, hope you don't mind:
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  (£165.00 @ Aria PC)
Motherboard: Gigabyte GA-H110M-H Micro ATX LGA1151 Motherboard  (£39.98 @ Amazon UK) use amazon prime trial for shipping.
Memory: Patriot Signature Line 8GB (1 x 8GB) DDR4-2133 Memory  (£46.11 @ Amazon UK)
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (£35.94 @ Aria PC)
Video Card: XFX Radeon RX 480 4GB RS Video Card  (£184.26 @ More Computers) free shipping.
Case: Thermaltake Versa H23  ATX Mid Tower Case  (£28.94 @ Ebuyer)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£47.99 @ Ebuyer) ebuyer has free shipping on orders above 50 pounds.
Total: £548.22
Generated by PCPartPicker 2017-01-29 12:57 GMT+0000
https://linustechtips.com/topic/730294-pc-build-for-a-friend/#findComment-9281018
There really isn't much to it, for 1080p gaming a 1060 is more than enough, and when it comes to processors, just get one that has 4 cores and above 3GHz clockspeed. I think that that's more than enough. Some say 8GB of RAM is enough, and they might be right, but I'd recommend 16GB. RAM frequency doesn't mean shit. Get an SSD as a boot drive, and a larger HDD as a storage drive. The rest doesn't really matter that much
https://linustechtips.com/topic/730294-pc-build-for-a-friend/#findComment-9281024
Edit: coincidentally posted identical build.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/730294-pc-build-for-a-friend/#findComment-9281029
Besides the build mentioned above, you can try to spend around 10 pounds more for a 6% faster CPU, faster memory and a better case, but that's up to you.
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor  (£168.59 @ Aria PC)
Motherboard: Asus H110M-A/M.2 Micro ATX LGA1151 Motherboard  (£44.99 @ Overclockers.co.uk)
Memory: Kingston Savage 8GB (1 x 8GB) DDR4-2400 Memory  (£48.25 @ Amazon UK)
Case: BitFenix Nova ATX Mid Tower Case  (£29.99 @ Aria PC)
Total: £560.01
Generated by PCPartPicker 2017-01-29 13:12 GMT+0000
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/730294-pc-build-for-a-friend/#findComment-9281051
Total: £560.01
Thanks, I'll pass it on. Much love
I'll check it out, thanks :)
I know but when i built mine I just went buy, buy, buy like I had no budget haha :P
Total: £548.22
Thank-You, i'll check it out :) Much love
https://linustechtips.com/topic/730294-pc-build-for-a-friend/#findComment-9281144
