there are some most pcie based
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/730228-4k-60fps-capture-card/#findComment-9280423
10 minutes ago, Dan Castellaneta said:
I think they do; they're obscenely expensive though, last I remember.
black magic makes some for 200$
https://linustechtips.com/topic/730228-4k-60fps-capture-card/#findComment-9280462
If you get into cinema gear they exist, but expensive. Most require signals that have no hdcp (there are a select few that break hdcp)
Windows 10 Edu | Asus ROG Strix X570-F Gaming | Ryzen 9 3950x | 4x 16GB G.Skill Trident Z RGB| ROG Strix GeForce® RTX 2080 SUPER™ Advanced edition | Samsung 980 PRO 500GB + Samsung 970 Evo Plus 2TB + 8TB Seagate Barracuda | EVGA Supernova 650 G2 | Alienware AW3418DW + LG 34uc87c + Dell u3419w | Asus Zephyrus G14
https://linustechtips.com/topic/730228-4k-60fps-capture-card/#findComment-9280541
1 hour ago, TheGleaner said:
Does one genuinely exist? Has anyone had any experience with one? Any recommendations?
Well there is a PCI-E card:
https://www.elgato.com/en/gaming/game-capture-hd60-pro
https://linustechtips.com/topic/730228-4k-60fps-capture-card/#findComment-9280587
43 minutes ago, TheGleaner said:
Another question is that I have heard that 4k 60fps is roughly 1/2gigabyte per second. Is that true, and if so, would you have to set up a ssd as a "queue" or a hdd?
a ssd will be needed unless you got some fast hard drives in raid 0.
https://linustechtips.com/topic/730228-4k-60fps-capture-card/#findComment-9285339
9 minutes ago, TheGleaner said:
Well thanks for your help, now I just have to wait for one to release/decide which one to buy in the meantime.
Off topic: 100th Post! Yay!
If youre still looking for one, there is an atmos shogun model that does 4k/60 and strips hdcp (if I recall what it is, ill send it to you).
https://linustechtips.com/topic/730228-4k-60fps-capture-card/#findComment-9323946
