Okay, So my Dell Optiplex 790 came in today, and i cant for the life of me get the 32bit windows 7 off and put on windows 7 64bit, i have bootable USB's (working (used rufus)), and I cannot get the new windows to install, whever i startup my computer it goes to the dell loading screen then to "intel boot agent pxe e61 media test failure" page, and i have gone into the bio, idk which to boot from UEFI or Legacy and whenever my computer starts it says press a key to start from USB and i do but then it boots windows, is there any was to clear my hdd and restart or comething? Please Help!!
https://linustechtips.com/topic/730223-help/
is the hdd formatted?
Main PC
CPU: i3-4160. RAM: 2x4GB Kingston ValueRam. GPU: Asus GTX750Ti OC 2GB (Palit StormOC 750Ti Bios). CPU Cooler: CoolerMaster Hyper 212X.
MoBo: Gigabyte GA-Z87-HD3. Storage: 1x Samsung 840 Evo. RAID 0: WD Scorpio Blue 500GB, WD Caviar Blue 500GB. PSU: Corsair CX500M.
Network: some TP-Link card that doesnt support 5.0Ghz. Case: Casecom Neptune CP-626 (the cooler doesnt fit so the side panel stays off).
Mouse: Logitech G430. Headphones: Sennheiser RS195. Keyboard: Lenovo KU0225. OS: Windows 10 Pro
stuff that isnt my main pc
Lenovo Thinkpad Edge E531 - Ubuntu 17.04 (Gnome Desktop)
Raspberry Pi 2 Model B - Not in Use
Raspberry Pi 3 - RetroPie
Phones/Tablets
Samsung Galaxy S3 - Lineage 14.1 (Android 7.1.1)
HTC One M7 - Dead Charging Port - Lineage 14.1 (Android 7.1.1)
HTC One M8 - Dead Sim Port -  Lineage 15 (Android 8.0.0)
Telstra 4GX Plus (ZTE Blade A462) - Android M Stock
iPhone 4S - Dead Battery Sensor (Stuck on too hot warning) - Latest iOS 9
iPhone 5 - MAIN PHONE - iOS 10.3.3
Consoles
Xbox One
Xbox 360 S
PlayStation 2 Fat
Headset: Plantronics RIG400HX
https://linustechtips.com/topic/730223-help/#findComment-9280397
2 minutes ago, JackyPhilibooty said:
it already has windows on it, but the wrong windows, im sorry but i dont know what u mean, how would i check?
you have 80 posts here, watch ltt but dont know what a formatted hard drive is? a formatted harddrive means you wipe everything off of it. they usually include 32bit os because the cpu only supports 32bit. did you check the cpu support?
Main PC
Phones/Tablets
Consoles
Xbox One
Xbox 360 S
PlayStation 2 Fat
https://linustechtips.com/topic/730223-help/#findComment-9280408
yes its an i5 2400 and it supports it, i cant format it because i cant boot off of anything except the hdd.
https://linustechtips.com/topic/730223-help/#findComment-9280410
check the boot order in bios make sure usb/dvd drive is first
Main PC
Phones/Tablets
Consoles
Xbox One
Xbox 360 S
PlayStation 2 Fat
https://linustechtips.com/topic/730223-help/#findComment-9280417
Main PC
Phones/Tablets
Consoles
Xbox One
Xbox 360 S
PlayStation 2 Fat
https://linustechtips.com/topic/730223-help/#findComment-9280427
i already set it, its on legacy and usb is first then goes dvd. it goes press any key to boot from USB then i press a key and 2 seconds later it boots windows
that means the setup boot device is corrupt
Main PC
Phones/Tablets
Consoles
Xbox One
Xbox 360 S
PlayStation 2 Fat
https://linustechtips.com/topic/730223-help/#findComment-9280432
okay idk what i did but i uplugged my HDD, it brought me to a scrren push f1 for this and f2 for that, no keys worked, so i spammed my keyboard and it brought me to my windows installation, i couldnt  install it onto anything because my hdd wasnt plugged in, so now im again at a loss because i lugged in and restarted and im back at square one now.
https://linustechtips.com/topic/730223-help/#findComment-9280465
i suggest trying to get a live linux usb/disc and formatting the harddrive in gparted. kali linux comes with gparted.
Main PC
Phones/Tablets
Consoles
Xbox One
Xbox 360 S
PlayStation 2 Fat
https://linustechtips.com/topic/730223-help/#findComment-9280469
before you do this. you have to be really sure you want to format your harddrive risking you will ever get windows installed. it should work though because there will be nothing to boot off of except the windows install.
Main PC
Phones/Tablets
Consoles
Xbox One
Xbox 360 S
PlayStation 2 Fat
https://linustechtips.com/topic/730223-help/#findComment-9280471
no because the hdd has windows on it. you cant clear your current windows installation while running windows off of that drive
Main PC
Phones/Tablets
Consoles
Xbox One
Xbox 360 S
PlayStation 2 Fat
https://linustechtips.com/topic/730223-help/#findComment-9280477
 try this though
Main PC
Phones/Tablets
Consoles
Xbox One
Xbox 360 S
PlayStation 2 Fat
https://linustechtips.com/topic/730223-help/#findComment-9280479
