Final Loop Configuration Help
Solved by W-L,
12 minutes ago, az said:Sorry, I don't quite follow. They don't both have a 4 pin connector which they draw power (and a pwm signal) from?
With the PWM series they have two connectors per pump one molex for power and 4 pin PWM connector so the power is not drawn from the motherboard as a D5 would easily overload it. So with a PWM splitter you can hook both pumps up so they work other at the same RPM.
