I've been thinking alot about building a PC for the first time, I've made a few topic regarding the parts and everything but I've recently found out that my case that I'm planning to buy, the Corsair SPEC 01 might not fit the hyper 212 cooler I was planning to use.
Here are the parts that I need to fit inside the case -
CPU - the Intel core i5 6600k - https://goo.gl/Ahs1pD
GPU - MSI RX 480 - https://goo.gl/fvQDr0
Motherboard -  gigabyte GA-z170x - https://goo.gl/1zTS3B
Ram - Corsair vengeance lpx ddr4 - https://goo.gl/QObGao
Storage - 1- WD blue 1 TB HDD - https://goo.gl/6JmIP
                2- samsung 120 GB ssd - https://goo.gl/pUuP7H
PSU -  Seasonic 620w - https://goo.gl/tSqfc9
Wireless Network Adapter - TP link - https://goo.gl/4wbOsW
Fans - circle 120mm fans *2 - https://goo.gl/oR8XKi
optical drive https://goo.gl/X5kB2R
case and cooler which won't work (unless someone has proof that it will?)
Cabinet -Corsair SPEC 01 - https://goo.gl/SDRLKr
CPU cooler - Hyper 212x - https://goo.gl/dBN2Ip
PLEASE ONLY USE THESE SITES TO FIND A CASE AND COOLER (as mostly PC part picker doesn't include the import and shipping costs which sometimes double the cost of the case) - www.Amazon.in     www.eBay.in
Requirements for CPU cooler -
-Good for medium overclocking (non water cooled)
-Can fit in case
Requirements for case -
-Can house all the components
-okay/good cable management
-easy to work in
-black/black and red to match my theme
-must have a glass side panel/window
Thanks to anyone who can help me
Also my budget in rupees is around 7000-8000 for the cooler and case combined!
https://linustechtips.com/topic/729780-casecpu-cooler-help/
Will be too tall for the case. Max CPU cooler clearance for the SPEC-01 is 150mm while the hyper 212x is 158m
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
Gigabyte RX 5600XT OC 6GB
-STORAGE-
1x Western Digital 1TB HDD
1x Samsung M.2 1TB SSD
1x Crucial 275GB MX300 SSD
-RAM-
Team Group 2 x 8GB DDR4 2400mHZ
-PSU-
Corsair CX-M Series CX650M
-MOBO-
Gigabyte Z170X-Gaming 6
-CASE-
Phanteks P400S Satin Black TG Edition
-PERIPHERALS-
Logitech g502 RGB and Blackwidow Elite.
-PART PICKER URL-
https://au.pcpartpicker.com/list/Jf9tbj
Have a Nice Day, Give us a Thumbs up if I helped you, Why Not?
https://linustechtips.com/topic/729780-casecpu-cooler-help/#findComment-9275846
1 minute ago, BlackBear101 said:
Yep, hence the topic.. :P
Sorry, read it wrong.
Thought you wrote will it fit.
A cooler you can try is the Cryorig H7.
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
-STORAGE-
-RAM-
-PSU-
-MOBO-
-CASE-
-PERIPHERALS-
-PART PICKER URL-
https://linustechtips.com/topic/729780-casecpu-cooler-help/#findComment-9275855
10 hours ago, BlackBear101 said:
Yes I've heard alot about that, and if it was available here I would definitely buy it, sadly it isn't :/
 I would recommend getting the SPEC-02 case, which has 157mm clearance and meets all your case requirements. You can then expand your search for CPU coolers. One you can get if you got the SPEC-02 case is the Phanteks PH-TC12DX. Although I would not recommend getting a CPU cooler that just fits.
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
-STORAGE-
-RAM-
-PSU-
-MOBO-
-CASE-
-PERIPHERALS-
-PART PICKER URL-
https://linustechtips.com/topic/729780-casecpu-cooler-help/#findComment-9278259
