Reformatting help
Solved by dalekphalm,
24 minutes ago, Santhox said:But wouldn't plugging 2 drives with windows on it mess things up?
Nope. Windows will boot from one drive only and will ignore the other drive.
The best way to ensure that it boots to the correct drive, however, is to do the following:
Make sure your M.2 drive is the only drive connected -> Install Windows
Power down PC, plug in the SATA POWER connector to the 2.5" SSD. Leave the SATA DATA cable unplugged.
Boot to desktop. Once at the desktop, plug in the SATA data cable. The 2.5" SSD will now get detected as a secondary drive.
Format the 2.5" SSD. And you're done.
Alternatively you could boot into a Linux Live OS like GPARTED and wipe the SSD from there, but that's a waste of time, in my opinion.
