Weird audio problems with headphone jack
I've owned headphones and earbuds before where the wiring gets messed up and sound only comes out of 1 ear unless you twist the cable a certain way. This is not the case I have right now.
If I plug in my headphones all the way into the jack (like normal), youtube and most things work fine, but then netflix will only play through 1 ear. If I pull out the plug just slightly so it's still in but not all the way, netflix will play just fine, but then the youtube audio is completely garbled.
I've never seen a headphone jack problem that changes based on the software. Any idea what's happening?
https://linustechtips.com/topic/729016-weird-audio-problems-with-headphone-jack/
If headphones are a 4 pole plug  (TRRS where one is mic) they may not like getting plugged into a 3 pole port.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
That would effect more than Netflix, while Netflix is the only program/site that checks for Windows headset settings of the ones he listed.
24 minutes ago, Kloaked said:
What headphones are they?
Sennheiser Urbanite XL
23 minutes ago, ImperialSteele said:
From the desktop, right-click your taskbar’s Speaker icon and choose Playback Devices.
Click your speaker or speaker’s icon and then click the Configure button.
I did that and in the configure there is a test. Both sides worked perfectly.
They are 4 pole (with a mic) but it's plugged into a laptop with a 4 pole connection.
EDIT: after testing each side on Netflix, one side works normally, the other works only for background music. I can't hear voices, but background music works almost perfectly.
EDIT2: Realized it's just an issue with a few episodes, I think it's good on my end. Thanks for the help guys!
