is the thermaltake pacific watercooling kit decent? ive read some reveiws saying its alright just want to see what others think.
CPU-I7 4790
COOLER-Be Quiet Pure Rock Slim
MOBO-Gigabyte Z97 HD3
RAM-8GB G.skill Ripjaws X
GPU-Gigabyte GTX 1060 6GB G1 Gaming
SSD-Kingston SSDnow 240GB
HDD-Segate Barracuda 1TB
PSU-Zalman ZM 550w Goldrock Semi-Modular psu
CHASSIS-ThermalTake Core X31
https://linustechtips.com/topic/728712-thermaltake-pacific-kit/
No they aren't really well regarded as they use mixed metals loops with aluminum rads. I would recommend to look into the EKWB L or S series kit or the better P series with the D5 pump.
https://linustechtips.com/topic/728712-thermaltake-pacific-kit/#findComment-9264616
how much do those kits cost bear in mind i am in new zealand
CPU-I7 4790
https://linustechtips.com/topic/728712-thermaltake-pacific-kit/#findComment-9264654
Take you pick the L and S series are more budget oriented, see if anyone distributes or carries EKWB products in New Zealand.
https://www.ekwb.com/shop/kits
https://linustechtips.com/topic/728712-thermaltake-pacific-kit/#findComment-9264664
budget is of no issue what is the most high end kit i could buy.
CPU-I7 4790
https://linustechtips.com/topic/728712-thermaltake-pacific-kit/#findComment-9264670
A good one I usually recommend is the P series since it has the better pump, if your case can house a medium thick 360mm read the P 360 kit is a pretty good option.
https://linustechtips.com/topic/728712-thermaltake-pacific-kit/#findComment-9264677
thanks for the help ill look into it
CPU-I7 4790
https://linustechtips.com/topic/728712-thermaltake-pacific-kit/#findComment-9264683
