Case? Specs?
https://linustechtips.com/topic/728686-do-i-need-case-fans/#findComment-9264209
3 minutes ago, VirusStorm said:
I will be overclocking my cpu using my h100i (the fans for the h100i are inside the case) but I will not be overclocking my gpu. Do I need a case fan?
Yes the GPU (if it's an aftermarket cooler, not blower style) will leave the hot air in the case. You need something to circulate the hot air, out. Just one in the front and an exhaust at the back should be fine.
Edit: If you don't like noise just get bequite fans and run them at a low rpm.
GPU: XFX RX 7900 XTX
CPU: Ryzen 7 7800X3D
https://linustechtips.com/topic/728686-do-i-need-case-fans/#findComment-9264216
In theory it's always good to have good air circulation in the case. Your GPU if it is not blower type, will just blow the air inside the case. Meaning it will blow out hot air in the case and "use back" the hot air to cool your GPU. Hope it make sense to you. Just get 1 for intake and 1 for output.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
https://linustechtips.com/topic/728686-do-i-need-case-fans/#findComment-9264346
