17 hours ago, Shiv78 said:
Try this. Add 8GB in a few weeks
PCPartPicker part list: https://de.pcpartpicker.com/list/hT6jbj
Price breakdown by merchant: https://de.pcpartpicker.com/list/hT6jbj/by_merchant/
CPU: Intel Core i7-7700 3.6GHz Quad-Core Processor  (€321.45 @ Mindfactory)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  (€54.99 @ Amazon Deutschland)
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2666 Memory  (€58.20 @ Amazon Deutschland)
Total: €434.64
Generated by PCPartPicker 2017-01-26 02:03 CET+0100
OR if you like to OC:
PCPartPicker part list: https://de.pcpartpicker.com/list/2h6gCy
Price breakdown by merchant: https://de.pcpartpicker.com/list/2h6gCy/by_merchant/
CPU: Intel Core i5-7600K 3.8GHz Quad-Core Processor  (€248.95 @ Mindfactory)
CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  (€30.79 @ Aquatuning)
Motherboard: ASRock Z270 Pro4 ATX LGA1151 Motherboard  (€119.55 @ Mindfactory)
Total: €457.49
Generated by PCPartPicker 2017-01-26 02:04 CET+0100
 What are pros and cons with OC ? I dont plan to throw in 300€ for water cooling.
USB 3.0 is compatible with USB 2.0 ? I mean I can plug in mouse which is 2.0 in 3.0 USB and its gona work ?
And what is with this purpel/green PS/2 port ? When I bought this curent PC I had to run in store and buy a USB keybord because there was not PS/2 port on my board
CPU:AMD Ryzen 7 5800X3D 8x 3.40GHz So.AM4
CPU Cooler: Corsair H100x 57.2 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX X470-F Gaming ATX AM4
Memory: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory
Video Card: Gainward Phoenix GS GeForce RTX 2080 Ti 11 GB Video Card
Power Supply: Corsair RM750x (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Pros: Fun, bragging rights. Quieter cooler than stock also, but you could just get a quieter CPU cooler down the line for the 7700. OCing helps improve performance if, say, after a few years you find your CPU performance lacking a bit.
Cons: More work, results vary
Yes, USB 3 is backwards compatible. No issues there.
Purple/green means you can run a keyboard OR mouse off of the same port. Since most peripherals now are USB, mobo makers have gone from 2 PS/2 to 1 or sometimes none. It's still a normal port, just not specifically for a mouse or keyboard like they used to be, works with both now.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
Total: €457.49
 I think Im gona go with this build. I searched a little bit and find out that water colling all in one solutions are not so
expensive, there are some for 50-70€. Then I can upgrade to water in future if those all in one solutions are god
In the future, rather than copy-paste, try selecting text in a post, then clicking Quote This or the Quote button on the bottom of the post
HOLA NIGHT THEMERS
OTHER TECH I OWN:
Ok, didnt know that
