My shitty camcorder (sony handycam hdr cx 220) doesn't take external mics - is it possible for me to buy a dslr camera mic and plug it into a phone and record like that? if so, what app or program should i use? please help
@deXxterlab97 @ARikozuM @Dawson Wehage
https://linustechtips.com/topic/728362-help-with-external-mic/
Firstly, yes you can plug a mic into a phone and record it using an app (just search for voice recorder and choose one).
Another option would be a dedicated recorder like the zoom h1, which has a built in mic and can be used with external mics. This would give slightly better quality, reduce battery strain on your phone and prevent anyone phoning you and possibly interrupting you.
https://linustechtips.com/topic/728362-help-with-external-mic/#findComment-9262161
2 hours ago, Dawson Wehage said:
Look for a mic input on the camera
doesn't have it - don't really have the money to be upgrading as im putting in a down payment for a comdom
edit: putting in a downpayment for a condo - phone autocorrected :P
Edited by gtx1060=value
https://linustechtips.com/topic/728362-help-with-external-mic/#findComment-9262189
