4 minutes ago, Scabral54 said:
Looking for a good mid range graphics card. Found the msi rx 470 for $159.99 with a $30 mail in rebate making it $129.99... should I get the rx 470 or pay a few bucks more for the gtx 1050ti? Or is it a preference at this point?
The RX470 is quite drastically more powerful. No reason to get the 1050ti.
http://gpu.userbenchmark.com/Compare/Nvidia-GTX-1050-Ti-vs-AMD-RX-470/3649vs3640
https://linustechtips.com/topic/728141-mid-range-graphics-card/#findComment-9258264
I'd take a RX 470 over a 1050 ti hands down. No fanboy stuff here, this is coming from a 1070 owner.
https://linustechtips.com/topic/728141-mid-range-graphics-card/#findComment-9258297
Get the RX 470
CPU: Ryzen 7 2700x cooled by Pure Rock Slim // RAM: Gskill Flare X 3200mhz CL14 2x16 32GB// GPU: Powercolor Red Devil RX 6650 XT 8GB// Motherboard: ASRock B450m Pro 4 // PSU: Seasonic G550 Gold 80+ // Storage: 4TB pcie nvme game drive, 512 GB m.2 sata3 OS Drive, 4 TB WD Red HDD // Monitor: Samsung S22D300 21.5" 1080p 60Hz, MSI 27" 1080p 144hz Freesync 1ms display // Peripherals:  Logitech fancy shmancy keyboard and moise with rgb and gaminess stuff, very fancy | Kingston HyperX Cloud Core headset
https://linustechtips.com/topic/728141-mid-range-graphics-card/#findComment-9258300
I suppose because RX470 and GTX1050Ti priced similarly. People assume they will have similar performance. Good trick from Nvidia.
RX470 is a far more powerful card than the GTX1050Ti. Actually similar to GTX1060 3GB. Just make sure not to get the reference model of RX470.
https://linustechtips.com/topic/728141-mid-range-graphics-card/#findComment-9258324
