Which should I buy?
5 members have voted
  1. 1. I don't have a gaming rig, but i will soon get one. What should I get?
    • Gaming Laptop
    • Gaming Pc
If you need a laptop then I'd recommend both a cheap-ish laptop and a desktop but obviously this depends on your budget :P
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/728012-need-help-deciding/#findComment-9256850
moved to new build planning
https://linustechtips.com/topic/728012-need-help-deciding/#findComment-9257407
