so i build my first pc made sure everything plug in and everything. but when i try to update drivers windows 10 crash with the error thread stuck in device driver. this always happen when i try to update amd drivers. can someone plz help
pc spc
i5-6500
gigabyte Ga-h170
RX 480
650 watts
and 16gb ram
https://linustechtips.com/topic/727785-made-my-first-pc/
chipset drivers installed? --> http://www.gigabyte.com/products/product-page.aspx?pid=5522#dl at the bottom of the page
uninstall all AMD components you can find.
reboot.
check again for AMD components :-)
install GPU drivers
hope that works :-)
https://linustechtips.com/topic/727785-made-my-first-pc/#findComment-9254031
do you have the latest correct AMD drivers? try DDU for installing any driver and cleaning up any failed installs and try again
Builds:
https://linustechtips.com/topic/727785-made-my-first-pc/#findComment-9254033
