Budget: $800 US for gaming, 1 monitor.
Hello Guys, I'm really bad with forums but i LOVE watching Linus tech tips on youtube and thought i would give this forum a shot. I'll do my best.
--I bought a computer from ibuypower back in 2013 and have been upgrading it piece by piece for the past 4 years. My ultimate goal is to upgrade this build, and build another gaming PC from my old parts. Lets get into it..
The original ibuypower computer came with. CPU: AMD 9590 FX, GPU: AMD HD 7990, Cooling: CPU Corsair 125 mm watercooled radiator, RAM: 2 Corsair Vengeance 4gb DDR3 RAM, Motherboard: GIGABYTE GA-990FXA-UD3 R5, PSU: 1200w 80 plus bronze, Case: NZXT Phantom Full-Tower Case (White).
I was having overheating problems with this rig and began to upgrade slowly. I now have GPU: EVGA GTX 1080 ftw, and RAM: 4 Corsair Vengeance 4gb DDR3 RAM
I applied new thermal paste to my CPU and added fans wherever they would fit in my case which helped with the heating issue. **I AM LOOKING FOR SUGGESTIONS and or ADVICE on where i should take it from here.
My goal is to go full INTEL and get a new CPU. I am currently looking at the Intel i7 6700k Skylake which would require me to upgrade my Motherboard and RAM (ddr4). I need help and suggestions on what products i should get to get the best performance for my gaming rig. And i don't know if this helps, but i use EVGA precisionx OC software for my overclocking. Also is my PSU good enough? Should i get something more than 80 plus bronze?
Any thoughts or suggestions would be greatly apprecicated thank you!
~Alex
https://linustechtips.com/topic/727759-build-tips-thoughts/
8 minutes ago, deXxterlab97 said:
I would get i7 7700k if you can for extra overclock boost very nice
For a high end build like this you should get good PSU. Pick one from Tier 2 and 1
Yours is fine but I don't know which PSU exactly. It could be a bomb
I am also curious about the max turbo frequency and integrated graphics neweggs compare says the i7 6700k has over the i7 7700k could you help me understand this?
https://www.newegg.com/Product/Productcompare.aspx?CompareItemList=-1|19-117-726^19-117-726%2C19-117-559^19-117-559
https://linustechtips.com/topic/727759-build-tips-thoughts/#findComment-9253767
2 hours ago, Nubaca said:
thank you for the quick reply! I'm curious about the PSU thing you posted. Pick one from either tier 2 or tier 1? is that what you meant?
Which unit do you have right now?
https://linustechtips.com/topic/727759-build-tips-thoughts/#findComment-9254068
1 hour ago, Nubaca said:
AZZA titan 1000w 80+ bronze, sheesh i thought it was 1200w
your psu is fine, shouldn't need an upgrade. i'd suggest this:
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($344.75 @ OutletPC)
Motherboard: ASRock Z270 Killer SLI/ac ATX LGA1151 Motherboard  ($143.98 @ Newegg)
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory  ($99.99 @ Newegg)
Total: $588.72
Generated by PCPartPicker 2017-01-24 04:51 EST-0500
and some better cable management.
https://linustechtips.com/topic/727759-build-tips-thoughts/#findComment-9254278
Total: $588.72
This is exactly what I was looking for Thank you
https://linustechtips.com/topic/727759-build-tips-thoughts/#findComment-9255733
