1 minute ago, JamesRainsGames said:
I want to put a water block and my gtx 1070 super clocked but I have no idea what to get, any help? I appreciate any criticism as long as it's constructive.
try the EKWB config :)
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/727399-gpu-water-cooling-help/#findComment-9249416
3 minutes ago, xentropa said:
Which brand you have?  Is it a reference version?
Superclocked, he said, so probably EVGA SC
qυoтe мe pleaѕe!
Me at the Apple store: "So how fast is this little macbook?"
Apple employee: "Cheetah Fast. Lightning Fast. It's Really, really, fast."
https://linustechtips.com/topic/727399-gpu-water-cooling-help/#findComment-9249432
So go to a website that sells it, frozenpc, performancepc, ekwb and get one. That's what I would use anyway, an ek block.
https://linustechtips.com/topic/727399-gpu-water-cooling-help/#findComment-9250109
