16295598_1140160379428281_2131651238_n.png?oh=615febe263aa2e56a194d880397cd8fc&oe=58882F1C
I know its hard to tell from the picture but my friends 8gb sapphire rx480 randomly does this where the screen is covered in white lines and then restarts. At first i thought it was artifacting but the effects are not permanent and can vary dramatically, it is also worth the mention that his gpu is brand new along with a brand new psu. I wondered if the motherboard could be responsible since its one of those ultra durable micro ATX boards with an AMD APU inside. what are your thoughts ?????
https://linustechtips.com/topic/727369-rx-480-problem/
I'd say it's a faulty GPU - so the answer would be to RMA it. But you should wait for more opinions first.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/727369-rx-480-problem/#findComment-9249237
GPU most likely. Drivers up to date? Also check if the GPU is seated properly: take it out and push it in, the slot might be filthy. Could help to see if this also happens on a different PC.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/727369-rx-480-problem/#findComment-9249262
Geez. Everyday there's a victim here or on reddit. I need to go offer sacrifice to the Rx 480 gods for delivering me from all these problems.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/727369-rx-480-problem/#findComment-9251796
1 hour ago, lots of unexplainable lag said:
Looks like AMD has a faulty batch of RX480s on their hands. You're not alone.
RMA it.
Is that so? How come, or not sure yet on the reason?
PSU Tier list
https://linustechtips.com/topic/727369-rx-480-problem/#findComment-9254531
Not sure on the reason, but you're not the only one with black screen issues and artifacting on an RX480.
Haven't seen people posting problems with RX470s and RX460s, so this may be limited to the full P10 chips only. Maybe there are some defect Stream Processors in there anyway causing issues (these would be disabled in an RX470 and an RX460 isn't a full P11 chip).
Ye ole' train
https://linustechtips.com/topic/727369-rx-480-problem/#findComment-9254634
so im thinking if i get him to test it in my system which is quite high spec and the card still artifacts i shall RMA it
https://linustechtips.com/topic/727369-rx-480-problem/#findComment-9262396
