Sup seople,
I've been looking for a while to buy myself a pc for some gaming, music production and video editing. My budget is around 500 euro. I can't really find the best price/quality stuff. Its hard to decide cuz there's so many different products out there. Any suggestions? (i already have a screen, mouse, keyboard, external audiocart) Thanks!
https://linustechtips.com/topic/727346-best-pc-for-500/
Euros or dollars? You've used both :P
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/727346-best-pc-for-500/#findComment-9248950
If it's euros, something like this?
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  (€65.89 @ Mindfactory)
Motherboard: Gigabyte GA-B250M-D2V Micro ATX LGA1151 Motherboard  (€74.56 @ Mindfactory)
Memory: Crucial Ballistix Tactical 8GB (1 x 8GB) DDR4-2666 Memory  (€56.41 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€56.80 @ Mindfactory)
Video Card: XFX Radeon RX 470 4GB Triple X Video Card  (€199.00 @ Amazon Deutschland)
Case: Zalman ZM-T1 PLUS MicroATX Mini Tower Case  (€23.67 @ Amazon Deutschland)
Power Supply: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply  (€50.63 @ Mindfactory)
Total: €526.96
Generated by PCPartPicker 2017-01-23 12:14 CET+0100
https://linustechtips.com/topic/727346-best-pc-for-500/#findComment-9248960
Total: €526.96
Seems pretty good, thank you! What parts are the most important if i want to upgrade? I guess cpu and Motherboard?
https://linustechtips.com/topic/727346-best-pc-for-500/#findComment-9249311
Maybe a SSD actually :)
The RX470 is almost as powerful as a 970 thus you'll be set for 1080p gaming for the next few years (albeit at slightly lower settings later on), the CPU isn't the best but it's more or less as good as an i3 6100 so you know...
The PSU is high quality enough where you may throw a 1070 at it for example and have it still run fine without having to worry about it blowing up, the motherboard will support kabylake and skylake i5/i7 so you have a nice CPU upgrade path ect. ect.
https://linustechtips.com/topic/727346-best-pc-for-500/#findComment-9249325
Ok, thx m8!
https://linustechtips.com/topic/727346-best-pc-for-500/#findComment-9251393
I have some parts laying around: Nvidia GTX 690 4gb, Msi b85-g43 Motherboard, Intel core i5-4460 CPU and an 8g ram stick. Will these parts improve the pc? I'm a little bit conserned because the gtx 690 is a little bit old... Also do i need another Power Supply if i use these parts instead?
https://linustechtips.com/topic/727346-best-pc-for-500/#findComment-9289606
