Posted January 23, 2017 So I wanted to do a build on and MSI Gaming ATX LGA1151 Mobo with a B150 chipset. I was leaning towards an intel i5-6500 CPU because I wanted a quad-core for more processing power for sandbox gaming. As I am sure most of you are aware, the i5-6500 does not have hyperthreading, but still boasts a decent 3.2GHZ core clock. As far as I know, the i5-6500 can be overclocked, but I keep reading that the B150 mobos cannot be overclocked by conventional means (or at all). Since this is my first build, I won't jump right into OCing, but I wanted to have the option to do so later on once I get a tad more experienced. I was wondering if this was an issue that can be fixed by an update to bios down the road, or if I should just invest in another mobo with a different chipset. I found some Z170s in the same price point. So any ideas? Should I invest in the Z170 and just get another processor that has hyperthreading? Or, should I just stick with more cores without hyperthreading, and just use the core clock on the b150? Link to comment https://linustechtips.com/topic/727336-simple-overclocking-question/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 23, 2017 If you use base clock overclocking on non K chip you will lose IGPU and temperature monitoring. Magical Pineapples
