hi am here because i have a hd 7750 and i using a a8 3800 and some months ago my pc just stop working and i just can´t fix it but today, I fix it and now my gpu isn´t doing the same fps was doing some month ago i dont know why but in saints row 3 i was playing in more then 40 fps in ultra fullhd and now ultra low 800x600 and 4 fps wtf wat do u think should i do if u can help me...
https://linustechtips.com/topic/727226-fps-problem-with-old-amd-gpu/
gpu probably died, take the gpu out and see what happens, if im right, integrated graphics should get higher fps
but the gpu not died because the problem i had beacuse i do some shit on the ram i dont knoiw how explain but i put one code on pront of control of windows and the computer just turn on normaly
6 minutes ago, deXxterlab97 said:
Reinstall driver? Are you connecting monitor to GPU or to Mobo?
man i update my drivers today on amd radeon setting is saying am using the newest drivers and am getting a low fps am think in format the hd and reinstall all driver i dunno
