Hey guys I have a 4k monitor & I simply dont play games, I just browse the web and maybe watch movies/shows/video's from time to time.
Currently my monitor is plugged into the motherboard using a display port 1.2 which is enabling me to drive the monitor at 60Hz in 4k.
But my dell desktop came with a Gtx 750Ti which has the following ports:
I did some research and found out that only HDMI 1.4 which my monitor has can drive my monitor at 60Hz in 4k.
My issue is the HDMI port on my graphics card is a mini HDMI & the one on the monitor is a normal sized HDMI.
I can't find a 1.4 hdmi cable that is mini hdmi to normal hdmi.
If you guys can help me out it'll be greatly appreciated!
I am from Canada so looking at shops in Canada or ncix.com [canada] or amazon.ca etc ... would be great!
Thanks for the help!
https://linustechtips.com/topic/726895-hdmi-14-help/
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244013
2 minutes ago, DocSwag said:
Only HDMI 1.4 carries 60Hz for 4k in my monitor i THINK.
Can you check for me please?
https://pcmonitors.info/reviews/philips-bdm4350uc/
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244015
1 minute ago, rasesh said:
Only HDMI 1.4 carries 60Hz for 4k.
No, actually hdmi 1.4 is 4K@30 hz whereas hdmi 2.0 is 4K@60hz. However, Kepler has technology built in that lets you do 4k@60 hz over hdmi 1.4 for a bit of reduction in color. I'm assuming the 750 ti does, too.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244019
Check the above comment please.
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244022
1.4 is 30Hz. 1.4 simply does not have the bandwith to manage it. So it could be that the info you have might be incorrect. It has nothing to do with the cable btw...
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244027
I have no idea what you're pointing at. HDMI 1.4 can only carry 4k@30 hz. Search it up. HDMI 2.0 can carry 4k@60 hz. Search it up. However, at one point Nvidia put out a driver update that allows hdmi 1.4 on Nvidia GPUs to output 4k@60 hz with a bit of reduction in color. Having an HDMI 2.0 cable is better in every way than having an hdmi 1.4 cable. It's backwards compatible so that's not an issue.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244034
u mean my monitor or hdmi 1.4?
HDMI 1.4.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244044
HDMI 1.4.
1 minute ago, Virtual_Gian said:
hdmi 1.4, your monitor you should find out its specs.
7 minutes ago, mineblaster said:
hdmi 1.4 @ 4k only dose 30Hz due to a cable bandwidth limitation
This is what it says about my monitor's ports:
The ports are backwards-facing and found to the right; 2 HDMI 2.0 (with MHL) ports, 2 DP 1.2 ports
what is MHL exactly?
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244053
MHL just means you can use your mobile devices with that monitor.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244064
HDMI cables are more or less HDMI cables. If it says a specific version, it's only certified as a guarantee that it'll work for the version. You could probably use a high quality HDMI 1.0 cable for HDMI 2.0
However according to https://pcmonitors.info/reviews/philips-bdm4065uc/, it's only HDMI 1.4 compatible, so it can't do 60Hz 4K.
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244090
Ya but Nvidia released a driver 2 years ago that allows you to do 4k 60hz on hdmi 1.4 with a bit of reduction in color.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244122
But that's outside the standard, so chances are the display won't do it.
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244127
Yeah thats what i meant.
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244172
True, my bad. I didn't realize the monitor itself has to support it. So then OP should probably stick with iGPU for video output.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/726895-hdmi-14-help/#findComment-9244173
