I installed a liquid cooler, but my temps got higher
2 minutes ago, Godlygamer23 said:
Can you hear it running with your ear next to it?
I tried to, but i cant get any closer without my ears being chopped off by the fans, but as close as I got, I couldnt
Do it from the other side of the case.
yeahhhh, no, its not running, just tried it
Is it connected properly? Is the connector fully secured on its header? Do you have other headers you can try? A 3-pin to molex adapter perhaps?
btw, im not very computer savy... I dont know what molex is
This is a molex connector:
Edited by Godlygamer23
Replaced link with uploaded image.
I DID IT!!!!!!!! THANK YOU ALL!!! IM RETARDED
What was the issue?
Wow, you wont believe what my mistake was....
I connected it to the cpu_fan which is 4pin.... the cable is 3 pin, and it was connected slightly off. wow. thanks for your time ;D
You can use the 4-pin header, you just won't get PWM.
so, should i buy a molex adapter? what is PWM?
No. If it's working now, don't worry about it.
PWM stands for "Pulse Width Modulation." The motherboard will send bursts of 12V current to allow for more granular control of pump/fan RPM. So instead of reducing voltage(going from 12V to 7V for example), fewer bursts are sent to the device to reduce the rate at which it turns.
oh, ok then. Hey, thanks for helping me
Happy to help.
