Hi Guys, im having a real headache choosing a UPS.
Im unsure what wattage i need? does it need to be the same or higher than the wattage of my 850watt PSU in my PC?
What i want it to run is my PC, Monitor, NAS and Modem in the case of a power outtage.
Can anyone help me?
Thanks.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/726621-choosing-a-ups/
are you wanting a desktop unit or one to fit in a rack mount? also how much power do you thing the devices use as in you computer you said you have an 850 watt power supply but do you use that much and your nas how much does it use give or take?
p.s most nsa brands have a list of tested/supported UPS lists so if its a branded nas start by checking there site.
https://linustechtips.com/topic/726621-choosing-a-ups/#findComment-9241068
you can measure the wattage you need by using one of those feedtrough wall wattage testers. plug the wallwatage tester into the wall, plug an extension box into that, plug everything you need to keep running in that and stress test the hell out of everything. add some more wattage onto that (i would say at least 50 watts to be sure but that highly depends on future expansion etc) and you should be fine.
https://linustechtips.com/topic/726621-choosing-a-ups/#findComment-9241133
Can anyone help me?
Thanks.
What are your system specs and devices you plan to have on the unit we can get a better idea of what is needed for needs.
https://linustechtips.com/topic/726621-choosing-a-ups/#findComment-9242600
My system specs are in my signiture and im wanting one to power my desktop not a rackmount.
i just need it to power my tower, monitor, NAS and modem in the case of an outage.
Internet Speed.....
https://linustechtips.com/topic/726621-choosing-a-ups/#findComment-9245217
Right ive just done a calculation using a PSU calculator and adding all the hardware i had in my PC and it came out that recommended UPS would be....
Load Wattage: 440 W
Recommended UPS rating: 850 VA
Recommended PSU Wattage: 490 W
Ive been looking on Amazon and found this within my price range and wonder what everyone thinks....
https://www.amazon.co.uk/APC-Back-UPS-BX-Uninterruptible-BX1400UI/dp/B00T7BYPDG/ref=sr_1_4?ie=UTF8&qid=1485115084&sr=8-4&keywords=ups
The reason i have also chosen this is that it will also be ok if i upgrade my PC to the new Ryzen AMD chip.
Internet Speed.....
https://linustechtips.com/topic/726621-choosing-a-ups/#findComment-9245306
Load Wattage: 440 W
Your system wouldn't draw more than 400W and with some extras that unit you have there will do well especially since you plan to upgrade in the near future.
https://linustechtips.com/topic/726621-choosing-a-ups/#findComment-9245645
Thanks
Internet Speed.....
https://linustechtips.com/topic/726621-choosing-a-ups/#findComment-9250708
