Comparison and help on builds .
Solved by WoodenMarker,
Whats the advantages/disadvantages to using an AMD system rather than an Intel system ?
Going with the 8320/8350 would be cheaper and more cores for BF4.
Lack of smaller form factors.
You're overspending if what you want to do is gaming.
Why 16GB ram? 8GB is plenty for gaming. Also, dominator platinums are a waste of money. Ram is ram. Brand has no affect on performance.
Caviar blacks aren't worth the money. Barracudas are only slightly slower and much cheaper.
My recommendations: http://pcpartpicker.com/p/1XV5y
