Yes, every machine ever has input lag. it's just a matter of physics and how much is between that button press and the end result.
as for playing games on it it would depend on the specs of the machine. and you said melee, an emulator i assume?
Edited by Archeval
Well snarky comments aside.
I'm going to assume since you said "Melee", you mean Super Smash Bros Melee
If you were planning to use your laptop to run a capture device to play from a console, then yes. There's a good chance there will be a significant amount of input lag for a game like Smash Bros Melee. If you were planning to run it from an emulator, then that's entirely dependent on how well the machine can run the emulator and your controllers (if you're using a converter it'll add input lag)
1 hour ago, DavethePCNoob said:
I have a asus rog g751jl (which i know i overpaid for because i was uninformed when i bought it) and my crt croaked recently so i want to know if my laptop has too much input lag to play on it?For melee that is.
Absolutely not. Laptops have the same inout lag as normal screens (negligable) so it doesnt matter. Its a drop in the bucket compared to you 230-300ms and you wont noice it.
- snip-
  • 4 years later...
Guest
