Patriot Viper 3 Series 1866MHz and H77 chipset
yes, you are, sounds like the RAM needs some question asking from MEMtest.
also, these are done on a stock or overclocked CPU? if OC, save profile and go
back to stock and re-do RAM.
My CPU is at stock
Should I run memtest on the values that I can boot from (1600mhz + auto) or the values that I should be getting (1866mhz + timings + freq above) and how many passes would you say ?
18/11/13 Edit -
Just a update on my situation. Ran memtest on the ram kit and all was well, but I couldn't pass on the multi-core mode. Decided to RMA and got a replacement kit. Couldn't get it to rated speed, ran memtest and got numerous errors. Got a full refund for it, much of been a bad batch or something ?
Unfortunately since I when through this, memory prices have shot up, so I'm stuck for a bit on my corsair 4gb kit. Oh well
Thanks for the guidance
