660TI 2GB ONLY USING 1.5GB MAX
Ilumic
Hi , my problem is, is it normal for my 660ti to only use 1.5GB out of its 2GB, when running very high end games , it has never gone over 1.5GB, im just wondering is it normal
CPU 5900x| GPU 3080ti FE| MOBO MSI MPG CARBON MAX| RAM 32GB VENGENCE PRO 3200Mhz| STORAGE Samsung 980 Pro 1TB,2X WDSN750,4TB Seagate Barracuda| COOLING 1x Corsair 360mm XR7 54mm Radiator,1x EK-CoolStream PE 360mm Radiator| GPU Block: Corsair Hydro X Series, XG7 RGB| CPU Block: Corsair Hydro X Series, XC5 RGB| Fittings: EK-Torque STC & Corsair Hydro X Series XF| Pump/Res: EK-Quantum Kinetic TBE 300 D5| Tubing: Corsair Hydro X Series XT Softline| Liquid: Corsair Hydro X Series XL5 Clear| Fans: 10x Corsair SP120 RGB
That's not normal
There are 10 types of people in this world, those who understand binary, and those who don't.
well, dont think this is a problem, what games are we speaking about? crysis 3, yea thats odd, but not many games use more than 1.5 gig vram at 1080p
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
Yes, i think it's normal
It's like normal RAM, it only uses what it needs
But i may be wrong
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
Games do necessarily use all of the RAM, all depends on game and resolution.
Gaming System: i7 3770k @4.6GHz, Gigabyte Z77X-UD5H, 8GB Corsair 1600MHz, 2 x MSI GTX 670 PE, Fractal R4, 256GB Crucial M4, Fractal Newton R3 1000W White
Steam Box: Xeon E3 1280 @ 3.5GHz, Intel S1200KP, 8GB Corsair White LP, 1x EVGA GTX 570, Fractal Node 304 White, 64GB Intel SSD, Fractal Tesla R2 650w White
im running games like battlefield 4 maxed out , and crysis 3 maxed out with aa on , and it only uses 1.5GB vram :(
I think your right :DD 8x msaa uses 1.9 Gb of my vram on crysis 3 , im glad its not a problem with my card thanks guys :DDD
no problem dude, glad to help
if everything is running well you shouldn't be worried :P
Could be that one of your chips are dead...
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
well try something like skyrim with 4k textueres. that will definitly eat your vram. see if it goes beyond 1.5GB
Yeh, normal. Same with system memory. It's there, but if it doesn't need to use it, it won't. Once you get higher res textures running through your game, it will start to eat up more VRAM. :)
