There is this little thing under my razor naga epic chroma wireless mouse and it's creating a lot of friction. Should I completely remove the label thing?
System
  • CPU
    I7 6700K Overclocked to 4.6 GHz at 1.33v
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
    GSKILL RIPJAWS V DDR4 16GB 3000MHZ
  • GPU
    MSI GTX 1070 GAMING X 8G overclocked to 2063 MHZ and 8900 MHZ memory clock
  • Case
    NZXT S340 RED
  • Storage
    WD 1TB BLUE AND SAMSUNG EVO 250GB SSD
  • PSU
    EVGA 650W GQ
  • Display(s)
    LG 25UM58-P ULTRAWIDE and LG 29UM58-P 29 ULTRAWIDE
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
    LOGITECH G502 PROTEUS SPECTRUM
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/723543-mouse-help/
You should remove Razer and add Logitech. Im sure it will fix your Problems.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/723543-mouse-help/#findComment-9206945
1 minute ago, Alaradia said:
yep just rip it off as long as your out of warranty i removed the label from mine a few months ago
Does it leave sticky residue?
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/723543-mouse-help/#findComment-9206955
1 minute ago, nerdslayer1 said:
yes
I wouldn't want that though. do you think if would come off with some rubbing alcohol and paper towel?
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/723543-mouse-help/#findComment-9206968
Just now, nerdslayer1 said:
yes
ok then I will remove the enitre label.
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/723543-mouse-help/#findComment-9206973
3 minutes ago, DisconnectedYT said:
If you are out of warranty then remove it....
and for anyone that says that razer mouses are built bad my Logitech G402's feet fell off after only a few months of use....
Im still on a G9x. My second G9 in 10 Years. My last Razer died after 12 Month´s. Weak plastic garbage.
https://linustechtips.com/topic/723543-mouse-help/#findComment-9207016
