I need a case for my first PC build
Solved by Skydiver,
4 minutes ago, Jamie_Taylor_4200 said:- No Optical drive
- ATX mobo
- don't really care if it has a window or not
- no water cooling (For now)
- just needs to look modest
Maybe the Fractal Design Define S might be something for you, there is a version with a window that is slightly more expensive. However it is made out of plexiglas if I remember correctly, which gets scratched very easily. I personally really like the very 'modest' look of this case :).
