2 minutes ago, Blejva said:
I`m interested in vid mod, but i don`t know what will happen if i tape over Vid[] pin. Will it change it from 0 to 1 and vice versa. I know that if you tape over bsel 2 that it will change it to positive or H.
Dafuck are you talking about? just watch tutorial on youtube about that mod..
https://linustechtips.com/topic/722989-lga775-cpu-pad-modding/#findComment-9201304
1 minute ago, Blejva said:
Just want to increase voltage.
I`m not interested in xeons for now. I have msi g41m-p28 mobo and e 3400. Mobo allows me to change fsb but voltage is fixed.
You don't need the sticker everyone here thinks you're talking about then. @Lays know anything?
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/722989-lga775-cpu-pad-modding/#findComment-9201319
I already overclocked e3400 to 3.3 ghz on stock voltage.
What i`m trying to do is something that i didn`t see until now.
I want to change vid pins, because that will change cpu voltage, values like in that datasheet that i attached.
And is threre any danger of frying cpu or motherboard with electrical tape by covering vid pins?
https://linustechtips.com/topic/722989-lga775-cpu-pad-modding/#findComment-9201339
