When it comes to case pressure I hear Neutral is the best.  I have a s340 and I'm had positive pressure for the most part (maybe a bit too much even).  My problem now, is that I've mounted a front radiator, thus taking up both front fan slots.  Now my case has negative pressure.
I've tested smoke entering the back brackets, So I made some changes to eliminate the Negative Pressure by lowering the Exhaust fan speed.  My exhaust fans are now at 45% (500rpms) which I think is ALREADY too low.  But still the negative pressure is still there.
CASE:     2 Corsair AF120's on the back for case fans
INTAKE:  2 NZXT 140 'Aerp' Fans (Static Pressure), with  RADIATOR & NZXT x62 Kraken
GPU:        Msi GTX 970
https://linustechtips.com/topic/722797-case-pressure-positive-negative-neutral/
neutral and positive are the best ones. you said you have 2 as intake. if you have 2 as exhaust is should be fine. if you want to be sure that you have positive air pressure, just put 2 fans in the front, with the rad (which you already have installed there) and have just one exhaust
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
You want a bit of positive pressure to help prevent dust build up as quick
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
Couple questions:
If I was to take one of the exhaust fans out.. Which would I take?  The back rear or the top rear?
Also, if I had a single exhaust.. Could i just have the two exhaust fans at a lower rpm (half the rpm of a single) so the airflow would technically be the same
