11 minutes ago, grayjimmie said:
hey I have been trying to record with OBS (also with Xsplit and I have the same problem) and I have no desktop audio. i have mic audio but the desktop audio is completely silent. i have looked all over and i just cant seem to find anything.
Did you set it up in the settings?
My fix was two things:
  1. At the bottom of the screen my volume meter (beside the speaker icon) was all the way to the left so I move it far right,
  2. I clicked the gear icon beside said speak icon, selected properties and then the right audio device.
Hope that helps.
